How to visualize beam elements
Moderator: bernd
Hi all,
how can i visualize the 1D beam section for 1Dlinear elements?
Thanks.
Thanks.
Re: How to visualize beam elements
the ccxtoolssolver has a property "Beam Shell Result Output 3D" If set to true the result mesh will be a 3D solid mesh. Is this what you are looking for?
No.is there a way I can look at the elements during the preprocessor phase?
The fastest way is making a frequency analysis. You only need a solver and a material for this.
[Solved] How to visualize beam elements
ok thanks
CalculiX can only check the model if you edit inp file before running:
replace the line
by
replace the line
*STATIC
*NO ANALYSIS
What does CalculiX do on *NO ANALYSIS ?fandaL wrote: ↑Wed Oct 03, 2018 7:36 am CalculiX can only check the model if you edit inp file before running:
replace the linebyCode: Select all
*STATIC
*NO ANALYSIS
It checks the input (including negative Jacobinas) and generates the frd mesh file
http://www.feacluster.com/CalculiX/ccx_ ... de280.html
wow ... wie need to implement this somehow!
Calculix solver need some upgrades...
