GMSH fails with precompiled FreeCAD from git
Moderator: bernd
Jee-Bee
Post by Jee-Bee »
I have difficulties with GMSH and the precompiled version of FreeCAD.
Even with a simple beam i don't get a mesh.
This is my log from report view. cleaned before opening file:
not a freecad file: .STP
Active analysis found: Analysis
We are going to start Gmsh FEM mesh run!
  Part to mesh: Name --> Box,  Label --> Cube, ShapeType --> Solid
  CharacteristicLengthMax: 1e+22
  CharacteristicLengthMin: 0.0
  ElementOrder: 2
  ElementDimension: 3
  c:\users\USER\appdata\local\temp\Box_Geometry.brep
  c:\users\USER\appdata\local\temp\Box_Mesh_TmpGmsh.unv
  c:\users\USER\appdata\local\temp\shape2mesh.geo
  C:/Users/USER/Downloads/FreeCAD_0.17.13488_x64_dev_win/bin/gmsh.exe
  Group meshing for analysis.
  Empty reference: SolidMaterial
  One material with no reference shapes. No need to make a group for materials.
  {'FemConstraintFixed': ['Face1'], 'FemConstraintForce': ['Edge7']}
('Unexpected error when creating mesh: ', <type 'exceptions.AttributeError'>)
I don't know have i something to do?
OS: Windows 7
Version: 0.17.13488 (Git)
Hash: 2891173923bcecaace64e0544f5773facbdef436
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.1.0
temp_beam.FCStd
(7.51 KiB) Downloaded 82 times
Jee-Bee
Re: GMSH fails with precompiled FreeCAD from git
Post by Jee-Bee »
Anybody can confirm that there is something wrong?? anything i can do to fix
I have checked the log file(i had that for that session) but same info as from report view
looo
Post by looo »
gmsh is also broken for me but in a different way. It hangs after this output:
  ElementOrder: 2
  ElementDimension: 3
  /tmp/Box_Geometry.brep
  /tmp/Box_Mesh_TmpGmsh.unv
  /tmp/shape2mesh.geo
  /home/lo/conda/envs/freecad/bin/gmsh
  No Group meshing for analysis.
The last 0.17 version works for me. This build was made on 07.04.18 from the 0.17 release source on github.
looo
Post by looo »
I think in my case this is related to loading a .unv file which is done with smesh, and we already have seen that there is something wrong with loading unv files with the smesh version I use.
So I guess this is not related to your problem.
sgrogan
Post by sgrogan »
Jee-Bee wrote: Thu May 03, 2018 6:46 am Anybody can confirm that there is something wrong??
It works for me. Maybe you need to update your version, it's older than the stable release.
OS: Windows 7
Version: 0.18.13647 (Git)
Hash: 52f4375625f96394224702741ff997463e5b02a5
Qt version: 4.8.7
OCC version: 7.2.0
"fight the good fight"
bernd
Post by bernd »
looo wrote: Thu May 03, 2018 10:41 am I think in my case this is related to loading a .unv file which is done with smesh, and we already have seen that there is something wrong with loading unv files with the smesh version I use.
BTW: if loading unv is broken you are not able to load FreeCAD FEM meshes at all. FreeCAD FEM meshes are saved inside FCStd files as unv meshes. Just unzip an FCStd file with a FreeCAD FEM mesh to see the unv.
bernd
bernd
Post by bernd »
Jee-Bee wrote: Thu May 03, 2018 6:46 am Anybody can confirm that there is something wrong?? anything i can do to fix
works here too on protable windows version ...
OS: Windows 10
Version: 0.18.13617 (Git)
Hash: 5941a32f715b5d0e47c2e38763e521d4307385a2
Qt version: 4.8.7
OCC version: 7.2.0
open FEM 3D example from StartWB, activate analysis, add Gmsh obj and mesh it.
Try export a cube from FreeCAD as brep and mesh it in Gmsh gui. Does it work for you?
Jee-Bee
Post by Jee-Bee »
Sorry hadn't much time and was forgotten after it...
I still get an error after running gmsh.
  CharacteristicLengthMin: 1.0
  ElementOrder: 2
  ElementDimension: 3
  c:\users\USERNAME\appdata\local\temp\Box_Geometry.brep
  c:\users\USERNAME\appdata\local\temp\Box_Mesh_TmpGmsh.unv
  c:\users\USERNAME\appdata\local\temp\shape2mesh.geo
  C:/Users/USERNAME/Downloads/FreeCAD_0.18.14098_x64_dev_win/bin/gmsh.exe
About the question for meshing... i did some checks. Exporting a cube works and meshes in gmsh.
the result "shape2mesh.geo" exist and looks the same as the manual created mesh.
for me it looks like the import fails...
OS: Windows 7
Version: 0.18.14098 (Git)
Hash: 0c33d00bfdf8270e7e5b33d792bf0ad9bbbfc819
Qt version: 4.8.7
OCC version: 7.2.0
and i would test it too on FreeCAD_0.18.14420_Conda_Py3QT5-WinVS2016_x64:
OS: Windows 7
Version: 0.18.14420 (Git)
Hash: 952a9a4a8064eb304bcde3d70fce0e851cd587d7
Python version: 3.6.6
Qt version: 5.6.2
but gmsh don't exist (at least not in the bin folder)
wingman
Post by wingman »
Was this error ever resolved ?
host kakamay
Post by host kakamay »
I have got a weird mesh from Gmsh, I have read many post related to it but I didn't find any solution for me.
This is my Freecad info:
OS: Arch Linux (KDE)
Version: 0.19.24291 (Git)
Branch: makepkg
Python version: 3.9.7
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
This is my Gmsh version: 4.8.4-git-566a1db
This is my netgen information:
NETGEN-6.2.2105-78-g6ae645ce
Developed by Joachim Schoeberl at
2010-xxxx Vienna University of Technology
2006-2010 RWTH Aachen University
1996-2006 Johannes Kepler University Linz
Including OpenCascade geometry kernel
NETGENDIR = .
Tcl header version = 8.6.11
Tcl runtime version = 8.6.11
using internal Tcl-script
optfile ./ng.opt does not exist - using default values
togl-version : 2
OCC module loaded
Thank you for using NETGEN
The command ccx return: Usage: CalculiX.exe -i jobname
while running the calculation I get error message from repport view:
CalculiX returned an error due to nonpositive jacobian elements.
14:50:21 nonpositive_jacobian_elements = [226, 233]
14:50:21 nonpositive_jacobian_elenodes = [1, 3, 3, 47, 71, 74, 277, 278, 321, 324, 329, 330]
14:50:21
14:50:21
Following some commands to copy. They highlight the nonpositive jacobians or to reset the highlighted nodes:
14:50:21 Gui.ActiveDocument.FEMMeshGmsh.HighlightedNodes = nonpositive_jacobian_elenodes
14:50:21 Gui.ActiveDocument.FEMMeshGmsh.HighlightedNodes = []
14:50:21
--------end problems---------
14:50:21 CalculiX finished with error 201.
