removing warning when creating a mesh from boolean fragments
Moderator: bernd
HoWil
Post by HoWil »
Good morning,
There is a warning :!: displayed when meshing boolean-fragments basically saying that problems can arise when meshing a component.
The thing is, that a boolean-fragments should by definition make no problems for meshing. There can't be any intersecting solids and therfore gmsh should always produce a nice result.
I use boolean fragments together with gmsh mesh in Fc on a daily basis and always clicking this warning is annoying :?.
I see three possibilities for implementing something against the above :
* inserting a check on the content of the boolean-fragments compound before the warning is risen
* insert a setting in the preferences to deselect for such warnings
* insert a checkbox at the warning to never show it again
This is for sure of low priority, since until now not so many use fc to create multi-body meshes. But I am sure that the numbers will rise at the latest when Openfoam and elmer are integrated.
Thanks in advance,
BR, Howil
bernd
Re: removing warning when creating a mesh from boolean fragments
Post by bernd »
ok, I see your problem. Would you make a mantis feature entry in FEM and assign it to me?
HoWil
Post by HoWil »
Done
https://freecadweb.org/tracker/view.php?id=2965
Looks like i can't assign bugs /issues.
bernd
Post by bernd »
HoWil wrote:Done
done! BTW there is a nice bug button in the forum issue #2965
HoWil
Post by HoWil »
bernd wrote:
HoWil wrote:Done
OK ... took me some time to find the 'bug' button in 'Reply'-mode.
Now I have it.... issue #0002965
Thx,
HoWil
