OpenSees, the Open System for Earthquake Engineering Simulation
Moderator: bernd
ebrahim raeyat
Re: OpenSees, the Open System for Herthquake Engineering Simulation
Post by ebrahim raeyat »
Thank you ebrahim raeyat. Can you point me to the resources for learning internal structure of FreeCad. How does it work and where should I start to make it print out the .tcl files for the OpenSees model.
my repo:
https://github.com/ebrahimraeyat/FreeCA ... r/opensees
scripting:
https://wiki.freecadweb.org/Python_scripting_tutorial
bernd
Post by bernd »
ebrahim raeyat wrote: Sun Oct 17, 2021 8:22 am
my repo:
scripting:
here you can find the work of ebrahim but rebased on latest FreeCAD master ... I do rebase this on a regular basis https://github.com/berndhahnebach/FreeC ... emopensees
But be aware this opensees solver code does not include the latest improvements in solver framework. I higthly recommend to study the mystran solver too.
BTW: the best resource of knwoledge in the regbard of FEM is to directly ask here in the forum.
cheers bernd
eccioloste
Re: OpenSees, the Open System for Earthquake Engineering Simulation
Post by eccioloste »
Hello.
I read past messages and I'm trying to figure out which is the best approach for Geotechnical FEM analysis.
Opensees has huge potentials in structural civil engineering, as well as geotechnical, but without GID interface I can't make it work.
Calculix is a good option.
I would like to know your thoughts about this.
I think it would be great to have one solver that could deal with most of civil engineering analysis requirements, and seismic analysis is an everyday problem. And obviously having freecad our pre-processor would be great!
Thank you for your inspiring work
Francesco
ebrahim raeyat
eccioloste wrote: Tue Nov 09, 2021 5:09 pm Hello.
Francesco
Hi Fracsesco. I think it is better to work on xcfem software. it is based on OpenSees and have huge properties , specially for design purpose.
ebrahim raeyat
bernd wrote: pinged by pinger macro
As I found FeView, I want to continue on this work. I studied the source code and I found the FeView uses pyvista for convert model and results to VTK format.
First I want to add OpenSees analysis for my OSAFE workbench to analyze the foundation on soil with springs.
The TCL input example file is attached. I compared the results with CSI SAFE software. Thanks.
soil.py
(2.32 KiB) Downloaded 29 times
ebrahim raeyat
NewJoker wrote: pinged by pinger macro
I created my foundation model file for opensees, But only used mesh from FreeCAD for this:
I used FeView for view the result. FeView Uses pyvista for show the results. It uses vtk unstructureGrid for this. I want to show the results in FreeCAD. How can I do that?
in Plotter.py it convert the output to vtk format. I can save each grid to vtk format, but my questions:
https://github.com/motiurce/FeView/blob ... ing.py#L31
1- how can I save all grids into one vtk file?
2- single vtk saving file, did not show correctly in FreeCAD.
@l_pereztato
