delete FEM results
Moderator: bernd
bernd
delete FEM results
Post by bernd »
If the FEM results from an analysis are deleted by pressing the del key or by right click and delete there will be a pop up asking if one really would like to delete the object because it has dependencies to the analysis. This was reported in issue #2080
On the contrary if python is used the popup does not pop up
- start FreeCAD --> start wb --> 3D FEM example --> python code
App.ActiveDocument.removeObject("CalculiX_static_results")
A grep to Object dependencies
grep -r "Object dependencies"
finds
src/Gui/MainWindow.cpp: tr("Object dependencies"),
src/Gui/CommandDoc.cpp: qApp->translate("Std_DuplicateSelection","Object dependencies"),
src/Gui/CommandDoc.cpp: qApp->translate("Std_Delete", "Object dependencies"), bodyMessage,
explains why it is not pop up in python, because it only pops up on GUI. Mhh but I do not really know how we could get rid of this popup for the FEM results.
Re: delete FEM results
This behaviour is implemented directly in the "Delete" command (StdCmdDelete::activated). However, at this point the command doesn't really know the context in which the deletion is performed. Only the view provider should decide if a deletion might break something or not because it knows best the internal structure.
Currently the deletion of FEM results is one of the few examples where this dialog is really annoying but it's not a FEM specific issue, it's a general issue.
I have to think about how to improve all this...
