3 Node Beam Elements not yet supported
Moderator: bernd
Re: 3 Node Beam Elements not yet supported
git commit 5466568 fixes all the reported problems.
makkemal
Post by makkemal »
Some enhancement of beam sections allowing user to select circular and pipe beam sections
https://github.com/makkemal/FreeCAD/tree/Beam_sections
bernd
Post by bernd »
wmayer wrote:git commit 5466568 fixes all the reported problems.
brilliant
bernd
Post by bernd »
makkemal wrote:Some enhancement of beam sections allowing user to select circular and pipe beam sections
included in my dev branch https://github.com/berndhahnebach/FreeC ... meshregion. I have a few minor things but I'm gone fix them right above yours, if you guys don't mind.
bernd
Post by bernd »
brilliant
Ahh one thing still remains. We've found a bug in unv reader ...
# 10 node tetrahedron --> tetra10 ###############
import Fem
tetra10 = Fem.FemMesh()  # a FEM mesh
tetra10.addNode( 6, 12, 18, 1)  # some nodes
tetra10.addNode( 0,  0, 18, 2)
tetra10.addNode(12,  0, 18, 3)
tetra10.addNode( 6,  6,  0, 4)
tetra10.addNode( 3,  6, 18, 5)
tetra10.addNode( 6,  0, 18, 6)
tetra10.addNode( 9,  6, 18, 7)
tetra10.addNode( 6,  9,  9, 8)
tetra10.addNode( 3,  3,  9, 9)
tetra10.addNode( 9,  3,  9,10)
tetra10.addVolume([1, 2, 3, 4, 5, 6, 7, 8, 9, 10], 88)  # a volume with ID: 88
tetra10.Volumes
obj = App.ActiveDocument.addObject("Fem::FemMeshObject","tetra10")
obj.FemMesh = tetra10
obj.FemMesh.Volumes
meshpath = u"/home/hugo/Desktop/femmesh.unv"
tetra10.write(meshpath)
mesh = Fem.read(meshpath)
mesh.Volumes
and even worse, because unv is used in FreeCAD to save FEMmeshes to fcstd files
doc = App.newDocument('mydoc')
import Fem
tetra10.Volumes
obj = doc.addObject("Fem::FemMeshObject","tetra10")
obj.FemMesh.Volumes
doc.saveAs(u"/home/hugo/Desktop/femmesh.fcstd")
App.closeDocument("mydoc")
FreeCAD.open(u"/home/hugo/Desktop/femmesh.fcstd")
App.ActiveDocument.tetra10.FemMesh.Volumes
after reopen the FreeCAD document the FemMesh has changed because the element number of the volume is not 88 but 1 instead.
Yes, that's the issue I found. But fixing smesh stuff is not my realm.
makkemal
Post by makkemal »
@Bernd
Yes go for it, we are just picking up some low hanging fruit in terms of functionality
bernd
Post by bernd »
IMHO we should not use radio buttons to choose the cross sections. We should go for a combobox and change the task panel depended on the chosen section type. Similar to Part --> create primitives.
For my first material refernce shape implementation I used such a task panel ui. https://github.com/berndhahnebach/FreeC ... aterial.ui You can open it in a simple ui - viewer and change the shapes of the model combo box
bernd
Post by bernd »
try attached one in an ui viewer ...
remove .txt
TaskPanelFemBeamSection.ui.txt
(13.47 KiB) Downloaded 164 times
bernd
Post by bernd »
@makkemal:
try https://github.com/berndhahnebach/FreeC ... meshregion
the section type is not yet updated with the combo box from task panel, means the type has to be chosen in property editor, but all length values can be edited in task panel already.
bernd
