check branch https://github.com/berndhahnebach/FreeC ... utocontact there is only one commit in the regard of autocontact, the head commit. You should find your way through. If not do not hestiate to ask ...Qumbetlian wrote: ↑Sun Mar 17, 2019 7:34 pm If someone can tell me how to bind my scrypt to "Create auto contact for compound object" button, I would be gratefully.
Fem constraint contact
Moderator: bernd
Re: Fem constraint contact
I improved my python script for automatically detecting contacts.
Now it can be set to not detect unuseful contacts between faces that are in contact but they are located on the same side (are not face to face) or if are perpendicular each other. Even more than that, by setting some parameters It can detect only contacts that are on a surface, or only contacts between faces that are tangent or virtually tangent if they get closer with a specified distance. This is useful for assembly that have screw joints.
Here is the new cod:
But now my problem is about Calculix. I have the following example: a body made in TPU through is passing a steel wire. I want to simulate the deformation of TPU body and wire, but Calculix give me a lot of errors. It's seem That Calculix not interact well with sliding contacts that have large displacements. This is may supposition after I tried two days to solve this problem. Can someone tell me if Calculix can solve this problem or not?
Here is a snapshot:
from PySide import QtCore, QtGui
import FreeCAD
import Fem
MinimumDistance=0.2 # Minimum distance between faces for which they are considered in contact
DetectOnlyFullSurfaceContacts=False # Only that faces that have contact between them on a surface whose area is non zero are detected
DetectOnlyTangencyContacts=True # Only that faces that have a tangential contact or can have a tangential contact if getting closer each other, with a distance defined in "MinimumDistance", are detected. Intersected faces are excluded
DetectTangencyOnlyByLine=False # Among faces that have a tangential contact, only faces that have a contact between them along a line or curve, are detected (not point contact)
# If all above variable are "False", then any pair of faces closer than "MinimumDistance" are considered in contact, including intersected faces
Slope = 1000000 # Contact stiffness
Friction = 0.3 # Friction
Scale = 1 # Scale
TangencyError = 0.0001
def areSurfacesInContact(face_1,face_2): # Detect if faces are in contact on a surface whose area is not zero
_com=face_1.common(face_2)
_result = _com.Area > 0
_com.nullify()
return _result
def areSurfacesTangent(face_1, face_2, distance, only_by_line=False): # Detect if faces are in tangential contact or can be in tangential contact
# Getting the normal on the surface through the first point closest toward another one surface
_norm_1=face_1.normalAt(face_1.Surface.parameter(distance[1][0][0])[0],face_1.Surface.parameter(distance[1][0][0])[1])
_norm_2=face_2.normalAt(face_2.Surface.parameter(distance[1][0][1])[0],face_2.Surface.parameter(distance[1][0][1])[1])
# print("Difference of tangent vectors = ", (_norm_1+_norm_2).Length)
if (_norm_1+_norm_2).Length < TangencyError:
if only_by_line:
if len(distance[1]) < 2: return False
# Getting the normal on the surface through the second point closest toward another one surface
_norm_1=face_1.normalAt(face_1.Surface.parameter(distance[1][len(distance[1])-1][0])[0],face_1.Surface.parameter(distance[1][len(distance[1])-1][0])[1])
_norm_2=face_2.normalAt(face_2.Surface.parameter(distance[1][len(distance[1])-1][1])[0],face_2.Surface.parameter(distance[1][len(distance[1])-1][1])[1])
if (_norm_1+_norm_2).Length < TangencyError: return True
else: return True
return False
def searchContacts(bodiesGroup): # Find the contacts between each surface of first body and surfaces of the rest of bodies
_contacts=[]
if len(bodiesGroup) <= 1:
return _contacts
_first_body=bodiesGroup[0]
_rest_of_bodies=bodiesGroup[1:len(bodiesGroup)]
_contacts=searchContacts(_rest_of_bodies) # Recursively search contacts
_prev_faces=len(_contacts)
i=0
for _face in _first_body.Shape.Faces: # Browse the list of shapes of the first body
j=0
for _neighbour_body in _rest_of_bodies: # Browse the list of neighbour body
for _neighbour_face in _neighbour_body.Shape.Faces: # browse the list of shapes for each body
_dist=_face.distToShape(_neighbour_face)
# print(" ****Distance from face ", i, " of ", _first_body.Name, " to the face ", j, " of ", _neighbour_body.Name, " is ", _dist)
if _dist[0] <= MinimumDistance:
if DetectOnlyFullSurfaceContacts: # Add only full surface contacts
if areSurfacesInContact(_face, _neighbour_face):
print("Adding contact due to surfaces in full contact")
_contacts.append([i,j]) # Appending indexes of faces in contact.Iindexes are according to number of faces checked in current instance of function
elif DetectOnlyTangencyContacts: # Add only tangential contacts
if areSurfacesTangent(_face, _neighbour_face, _dist, DetectTangencyOnlyByLine):
print("Adding contact due to surfaces tangency")
else:
print("Adding all contacts between surfaces closer than ", MinimumDistance)
j=j+1
i=i+1
for k in range(0,_prev_faces): # Correcting the indexes returned from the previous instance according to number of faces founded in the current instance
_contacts[k][0]=_contacts[k][0]+i
_contacts[k][1]=_contacts[k][1]+i
for k in range(_prev_faces,len(_contacts)): # Correcting the index of faces belonging to the rest of bodies according to number of faces belonging to the first body
return _contacts
def addContacts(facesPairs, group): # Adding contacts according to the faces pairs given in first argument
_active = FemGui.getActiveAnalysis()
for _pair in facesPairs:
_obj = FreeCAD.activeDocument().addObject("Fem::ConstraintContact","FemConstraintContact")
_obj.Slope = Slope
_obj.Friction = Friction
_obj.Scale = Scale
_obj.References = [(group,"Face"+str(_pair[0]+1)),(group,"Face"+str(_pair[1]+1))]
_active.addObject(_obj)
def errorDialog(msg):
# Create a simple dialog QMessageBox
# The first argument indicates the icon used: one of QtGui.QMessageBox.{NoIcon, Information, Warning, Critical, Question}
_diag = QtGui.QMessageBox(QtGui.QMessageBox.Warning, 'Error in AutoContacts', msg)
_diag.setWindowModality(QtCore.Qt.ApplicationModal)
_diag.exec_()
class Error(Exception):
"""Base class for other exceptions"""
pass
class ActiveAnalysis(Error):
"""Raised when something go wrong with analyse"""
pass
try:
if not FemGui.getActiveAnalysis():
raise ActiveAnalysis
for obj in FreeCAD.ActiveDocument.Objects: # seach all objects in document
contacts=[]
objName = obj.Name
objLabel = obj.Label
if 'Compound' in objName: # detect if an oject is compound
bodiesGroup=[]
group=App.ActiveDocument.getObject(objName).OutList # get the list of members object
for member in group:
if member.Shape.Faces: # If member is having faces, then add him in group
bodiesGroup.append(member)
else:
print("Not a Shape")
contacts=searchContacts(bodiesGroup)
if len(contacts): addContacts(contacts, obj)
except ActiveAnalysis:
errorDialog("There is not an active analysis.\nPlease create a FEM analyse first!")
except Exception:
print("Not object")
Here is a snapshot:
Sorry for being absent
I figured out what was going wrong it seems some of the functions I used was for python 2.7 switching over to 3.6 gives different results
Hopefully I get enough time to fix this
Thanks
Michael
Thanks
Michael
Basic code working again
Some minor issue with the more complicated ones
https://github.com/makkemal/FreeCAD/tree/femautocontact
I have a request for the contact constraint.
Would it be possible to create multiple master / slave contacts at once?
I have added a example where i have two objects but need 3 contact constraints(more are possible
). if i have to create a single contact constraint with one master and 3 slaves(split up automatically without user or whatever)
- example_contact.FCStd
- (46.57 KiB) Downloaded 115 times
I'm the oly one issueing this?
oke when i'm at my home computer i make a feature request so it is more difficult to be forgotten
I like the idea but only getting to the code every now an then I once again have problems rebasing my code
https://github.com/makkemal/FreeCAD.git
FEM has some many formatting changes can anybody recommend a editor/settings which which these updates are handled easier ?
Every time I have time to progress I spend a day rebasing code
Thanks
Michael
Thanks
Michael
