Help with testing - part 2
Moderator: bernd
PrzemoF
Post by PrzemoF »
I need help with testing some FEM changes. The changes are here:
https://github.com/PrzemoF/FreeCAD_sf_m ... ree/fem_v3
In brief:
1. Materials now are read from 3 locations:
- standard FreeCAD material directory
- a sub directory "Materials" in user settings directory, on linux it's i.e. "~/.FreeCAD/Materials"
- an user defined directory that can be set in FEM preferences
Each location has it's own icon assigned
2. Material description is show below Poisson ratio
3. Location of CalculiX ccx binary can be defined in FEM preferences. That location overrides the usual ccx location
Summary:
Przemo Firszt (8):
FEM: Add option to define ccx path in Preferences
FEM: Read materials from user settings directory
FEM: Rename dirname to sytem_mat_dir
FEM: Add option to define custom material directory
FEM: Add icons to materials
FEM: Use chooseMat directly set set initial value for material
FEM: Add function for adding materiales from a directory
FEM: Show material description below combo box
src/App/Application.h | 1 +
src/App/ApplicationPy.cpp | 11 +++
src/Gui/Icons/resource.qrc | 1 +
src/Gui/Icons/user.svg | 645 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
src/Mod/Fem/Gui/DlgSettingsFem.ui | 195 +++++++++++++++++++++++++++++++++---------
src/Mod/Fem/Gui/DlgSettingsFemImp.cpp | 4 +
src/Mod/Fem/MechanicalAnalysis.py | 19 +++--
src/Mod/Fem/MechanicalMaterial.py | 39 +++++++--
src/Mod/Fem/MechanicalMaterial.ui | 10 +++
9 files changed, 867 insertions(+), 58 deletions(-)
create mode 100644 src/Gui/Icons/user.svg
Please test! :D
FreeCAD_FEM_ccx_and material_dir.png (96.74 KiB) Viewed 2795 times
bernd
Re: Help with testing - part 2
Post by bernd »
Just tested your improvements on Debian Jessie. Works very well. Great I like them. found some small thing. It is possible to change the values for every material but the changed values are not taken for FEM. Allways the one from the material care are taken. Even for the none material. I would expect if i choose none and put in some values these values are taken. Same for all other materials. If it is possible to change the values one expects them to taken for the calculation.
PrzemoF
Post by PrzemoF »
Thanks for the feedback - I'll have to think how to handle it. I have a few ideas...
Wouldn't it make more sense to fill the line edit with the default path of ccx. This way it's more obvious to the user from where ccx is used.
PrzemoF
Post by PrzemoF »
It certainly would. I can do it on linux, but I have no idea how to do for windows/mac.
Here you have the path to ccx https://github.com/FreeCAD/FreeCAD_sf_m ... is.py#L209
So, you only have to set this as the default in the preferences.
PrzemoF
Post by PrzemoF »
Thanks, I'll use it!
sgrogan
Post by sgrogan »
Thanks PrxemoF :D
Win 7 VS 12 2013 Debug x64 from fem_v3
OS: Windows 7
Version: 0.16.4795 (Git)
Branch: fem_v3
Hash: 47deb848aaf4f857cf6406b9be92b57651458532
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
PrzemoF wrote:1. Materials now are read from 3 locations:
Works Perfectly (On Windows .../User/USERNAME/Appdata/Roaming/FreeCAD/Materials
PrzemoF wrote:3. Location of CalculiX ccx binary can be defined in FEM preferences. That location overrides the usual ccx location
Works perfectly
PrzemoF wrote:2. Material description is show below Poisson ratio
Works for default ABS material
Copying 1C22 to the user defined directory gives this error(after editing description)
material data:
 Name = CalculiX
 YM = 210000 MPa
 PR = 0.3
  File "C:\Users\Chris\Desktop\Fem_v3\Mod\Fem\MechanicalMaterial.py", line 188, in chooseMat
    self.obj.Material = Material.importFCMat(str(name))
  File "C:\Users\Chris\Desktop\Fem_v3\Mod\Material\Material.py", line 60, in importFCMat
    Config.read(fileName)
  File "C:\Users\Chris\Desktop\Fem_v3\bin\lib\ConfigParser.py", line 305, in read
    self._read(fp, filename)
  File "C:\Users\Chris\Desktop\Fem_v3\bin\lib\ConfigParser.py", line 512, in _read
    raise MissingSectionHeaderError(fpname, lineno, line)
ConfigParser.MissingSectionHeaderError: File contains no section headers.
file: C:\Users\Chris\Documents\FreeCAD\User_Materials\1C22.FCMat, line: 1
'\xef\xbb\xbf; 1C22 - 1.0402 - EN 10083-1\n'
Contens of 1C22.FCMat after editing:
; (c) 2014 M. Münch - GNU Lesser General Public License (LGPL)
; information about the content of this card can be found here:
; http://www.freecadweb.org/wiki/index.php?title=Material
[General]
Vendor=
Name=1C22
NameDE=C22
MaterialNumber=1.0402
Norm=EN 10083-1
KindOfMaterial=Heat-treatable steel
KindOfMaterialDE=Vergütungsstahl
SpecificPrice=
Father=Metal
ProductURL=
; Specific Weight - kg/m³
SpecificWeight=7800
Description: This is a Test of Material Description
DescriptionDE=kleiner Vergütungsdurchmesser, gut schweißbar
[Mechanical]
;Ultimate Tensile Strength - Rm - N/mm²
UltimateTensileStrength=400
; Yield Strength - Re - N/mm²
YieldStrength=230
CompressiveStrength=
; Youngs Modulus - E-Modul - N/mm²
YoungsModulus=210000 MPa
; ModulusOfShare - G-Modul - N/mm²
ModulusOfShare=81000
Elasticity=
FractureToughness=
; Ultimate Strain - Bruchdehnung - %
UltimateStrain=27
; Thermal Expansion Coefficient - Ausdehnungskoeffizient - 1/K
ThermalExpansionCoefficient=1,10E-05
[FEM]
; Poisson Ratio - Querkontraktionszahl
PoissonRatio=0.3
"fight the good fight"
PrzemoF
Post by PrzemoF »
Thanks for testing! That looks like a material parser error - I'm doing some fixes right now, so I'll ask you to test it again with the new version.
sgrogan
Post by sgrogan »
Whenever your ready :D
Did you notice you made the headlines? Great Job!
http://libregraphicsworld.org/blog/entr ... ty-funding
