Select All Edges context menu option for Part Design fillets and chamfers
TheMarkster
Post by TheMarkster »
https://github.com/FreeCAD/FreeCAD/pull/5269
Snip macro screenshot-41f19f.png (50.26 KiB) Viewed 3969 times
uwestoehr
Re: Select All Edges context menu option for Part Design fillets and chamfers
Post by uwestoehr »
Many thanks!
Can you please also document it in the release notes:
- https://wiki.freecadweb.org/Release_not ... provements
I tried the feature and thought it would also solve this issue:
- insert a cube (additive primitive of PD)
- select it and click the fillet icon
result: you get an error message
But thanks to your new feature instead all edges of the cube could be selected and the fillet dialog be opened. Could you maybe add this functionality?
TheMarkster
uwestoehr wrote: Mon Jan 03, 2022 7:27 pm Many thanks!
Good idea.
https://github.com/FreeCAD/FreeCAD/pull/5328
