github PRs not rebased on master sorted by github user
bernd
Post by bernd »
these PR need rebase to make the CI run ... Take into account these are the github user names. They might not the same as the ones used here at the forum.
Only rebased PRs will be recognized by the CI https://gitlab.com/berndhahnebach/FreeC ... e=branches
List will be updated, if PRs gets merged or rebased
github user ByronMontgomerie:
https://github.com/FreeCAD/FreeCAD/pull/4987
github user totaru:
https://github.com/FreeCAD/FreeCAD/pull/4943
github user manuel-buchner:
https://github.com/FreeCAD/FreeCAD/pull/4887
github user matthijskooijman:
https://github.com/FreeCAD/FreeCAD/pull/4859
github user CarlOlson:
https://github.com/FreeCAD/FreeCAD/pull/4740
github user pilhuhn:
https://github.com/FreeCAD/FreeCAD/pull/4620
github user davidosterberg:
https://github.com/FreeCAD/FreeCAD/pull/4556
github user aapo-aapo:
https://github.com/FreeCAD/FreeCAD/pull/4524
github user vosk:
https://github.com/FreeCAD/FreeCAD/pull/4302
github user eszlari:
https://github.com/FreeCAD/FreeCAD/pull/4110
github user vocx-fc:
https://github.com/FreeCAD/FreeCAD/pull/3842
github user Vanuan:
https://github.com/FreeCAD/FreeCAD/pull/3772
github user kryptokommunist:
https://github.com/FreeCAD/FreeCAD/pull/3569
github user hobbes1069:
https://github.com/FreeCAD/FreeCAD/pull/3525
github user realthunder:
https://github.com/FreeCAD/FreeCAD/pull/4535
https://github.com/FreeCAD/FreeCAD/pull/3646
https://github.com/FreeCAD/FreeCAD/pull/3625
https://github.com/FreeCAD/FreeCAD/pull/3535
https://github.com/FreeCAD/FreeCAD/pull/3255
https://github.com/FreeCAD/FreeCAD/pull/2759
https://github.com/FreeCAD/FreeCAD/pull/2758
https://github.com/FreeCAD/FreeCAD/pull/2723
carlopav
Re: github PRs not rebased on master sorted by github user
Post by carlopav »
Thx @bernd for the head-up. My PRs are just Draft draft PRs and are not meant to be merged as they are now. In my opinion no need to waste compiler resources with them at the moment. I'll rebase them as soon as I'll add more commits. If you think it's necessary to rebase them now let me know and i'll do it asap.
PrzemoF
Post by PrzemoF »
Just to be clear: they need to be manually rebased because they can't be auto-rebased?
Edit: let me know if auto-rebasing is good enough. The gh->gl script does that and I could refresh all pr branches in my gl repo.
bernd
Post by bernd »
PrzemoF wrote: Sun Sep 26, 2021 2:57 pm Just to be clear: they need to be manually rebased because they can't be auto-rebased?
great offer. IMHO the devs themselv should do the rebase. Thus it is much simpler for the CI. We can do some smart automatically stuff with them. Still the script is useful to know which PR does rebase.
BTW: welcome back. There has happened a lot in the regard of CI. I will post all my scripts soon.
bernd
Post by bernd »
carlopav wrote: Sun Sep 26, 2021 2:02 pm Thx @bernd for the head-up. My PRs are just Draft draft PRs and are not meant to be merged as they are now. In my opinion no need to waste compiler resources with them at the moment. I'll rebase them as soon as I'll add more commits. If you think it's necessary to rebase them now let me know and i'll do it asap.
I it in not to much work for you it would be cool if you could rebase them on latest master. Thus they would be recognized by the CI even if it is not needed at the moment. But I would like to be as much PRs as possible to be automatically recognized by the CI.
PrzemoF
Post by PrzemoF »
Thanks! All the script does it "try to rebase" and quit on fail. I'll take what's on gh and push it to gl.
carlopav
Post by carlopav »
done!
PrzemoF
Post by PrzemoF »
OK, the PRs are being pulled, rebased on top of master and force pushed to gitlab. It'll take ~8-10 hours to build them based on the previous tests. I might make the script more user friendly it we plan to use it in the future. I'll post the report of what failed to rebase soon.
Edit:
50 rebased OK, 21 failed to rebase on top of the master branch:
$ git branch | grep gh-pr | grep -v abort
  gh-pr-3256
  gh-pr-3625
  gh-pr-3716
  gh-pr-3842
  gh-pr-4110
  gh-pr-4118
  gh-pr-4133
  gh-pr-4277
  gh-pr-4460
  gh-pr-4503
  gh-pr-4524
  gh-pr-4535
  gh-pr-4626
  gh-pr-4685
  gh-pr-4740
  gh-pr-4752
  gh-pr-4787
  gh-pr-4803
  gh-pr-4858
  gh-pr-4859
  gh-pr-4860
  gh-pr-4884
  gh-pr-4887
  gh-pr-4940
  gh-pr-4943
  gh-pr-4959
  gh-pr-4965
  gh-pr-4973
  gh-pr-4975
  gh-pr-4985
  gh-pr-4989
  gh-pr-4991
  gh-pr-4992
  gh-pr-4998
  gh-pr-4999
  gh-pr-5008
  gh-pr-5009
  gh-pr-5023
  gh-pr-5028
  gh-pr-5034
  gh-pr-5037
  gh-pr-5042
  gh-pr-5045
  gh-pr-5049
  gh-pr-5050
  gh-pr-5051
  gh-pr-5059
  gh-pr-5061
  gh-pr-5062
  gh-pr-5063
fedora:/home/przemo/software/FreeCAD/FreeCAD
$ git branch | grep aborted
  gh-pr-2723-rebase-aborted
  gh-pr-2758-rebase-aborted
  gh-pr-2759-rebase-aborted
  gh-pr-2862-rebase-aborted
  gh-pr-3062-rebase-aborted
  gh-pr-3255-rebase-aborted
  gh-pr-3525-rebase-aborted
  gh-pr-3535-rebase-aborted
  gh-pr-3569-rebase-aborted
  gh-pr-3646-rebase-aborted
  gh-pr-3767-rebase-aborted
  gh-pr-3772-rebase-aborted
  gh-pr-3775-rebase-aborted
  gh-pr-4302-rebase-aborted
  gh-pr-4425-rebase-aborted
  gh-pr-4556-rebase-aborted
  gh-pr-4620-rebase-aborted
  gh-pr-4911-rebase-aborted
  gh-pr-4933-rebase-aborted
  gh-pr-4952-rebase-aborted
  gh-pr-4987-rebase-aborted
$ git branch | grep aborted | wc -l
21
$ git branch | grep gh-pr | grep -v abort | wc -l
50
bernd
Post by bernd »
FYI: for the branches which are rebased and the CI has finished a comment will be made. It looks like this. https://github.com/FreeCAD/FreeCAD/pull ... -927380726
PrzemoF
Post by PrzemoF »
If you want to register my laptop as a temporary builder for your repo please PM me the token. I have delay with getting parts for the permanent builder, so I guess we have to use what's at hand. The builds in my repo will be finished in about 30 minutes from now.
