[Resolved] PR #4942 new option to show/hide sketcher constraints
Locked
uwestoehr
Post by uwestoehr »
The Sketcher WB has a performance problem when a sletch has several 100 constraints. Take for example the case you design a circuit board. Here is an example file:
Sketch-Constraint-test.FCStd
(28.54 KiB) Downloaded 124 times
- open in the file the "Sketch-Elektrode-00"
- despite the sketch is relatively simple, it has > 500 constraints. The problem is that they pollute the view:
For real-life you need 2 views to keep the overview, to present and discuss the design with colleagues and customers:
A: only with the datum constraints displayed
B: and without any constraints displayed
Let's try to get view A:
- we first need to hide all constraints, so we go into the constraints list, select the first constraint, keep Shift pressed and select the last constraint
result: this takes here 50 seconds (and severely, Windows tells me that FreeCAD is not responding anymore just after 5 seconds, so FreeCAD misses to tell the OS, that it is still alive, just calculating)
- now right click and in the context menu choose "Hide constraints"
result: this takes here 101 seconds
- now filter the datums
- select all datums -> takes 7 seconds
- show all datums -> takes 13 seconds
So in total one needs 171 seconds, almost 3 minutes to get the desired view.
Once one has this view one usually needs only to toggle between view A and B, these are each 20 seconds.
The PR implements the option to hide/show all currently listed constraints to save the time one needs to select all constraints manually.
So going from all constraints shown to view A needs with this option "only" 114 seconds and when toggling the datum view, 13 seconds.
There is still room for improvement since it is unclear why hiding/showing just 4 constraints needs 13 seconds. But the new option is in general a convenience option to save the annoying manual selection of all listed constraints.
abdullah wrote: .
Re: PR #4942 new option to show/hide sketcher constraints
Good addon - thanks!
(While I wouldn't encourage people to sketch/model in that way.)
uwestoehr
Post by uwestoehr »
chrisb wrote: Mon Jul 26, 2021 9:23 am (While I wouldn't encourage people to sketch/model in that way.)
How else should I design?
M4x
Post by M4x »
Nice idea! The."FreeCAD is missing to tell the OS that it is still alive" happens regulary for me. Mostly in TechDraw or when I'm creating meshes. I assume it's a general problem.
Regarding the design discussion: Maybe a seperate thread would be a good idea here.
obelisk79
Post by obelisk79 »
I recently have been thinking about this kind of option.
I am currently unable to test the PR. However would it be much more difficult to have a checkbox that 'auto hides' geometric constraints? So only constraints for currently selected sketch elements are displayed?
Explanation: If I sketch a rectangle, I inherently understand that vertical and horizontal lines are constrained. However, if I want to see, modify or delete those constraints I can select the associated element (line, vertex, curve etc) and they would be displayed. Dimensional constraints would always be visible and if a user ever decided they need to see them all at once, they could either "CTRL-A" the sketch or toggle the setting in the tasks panel.
Just a thought.
uwestoehr wrote: Mon Jul 26, 2021 12:21 pm How else should I design?
Hard to say without the file and without knowing what you model, but you can almost always split the sketch in two or more. From what I can see, the sketch seems to by symmetric. You may use this fact by applying an appropriate pattern function.
C_h_o_p_i_n
Post by C_h_o_p_i_n »
Hi All,
but ... splitting a sketch also looks like a "workaround" - wouldn't a more general solution be better ?
how about an tag to define parts of the sketch as "static" ( or ready/or done) ... so that the solver does not need to "solve" / touch this (tagged) part of the sketch any more ?
Regards,
Stefan
C_h_o_p_i_n wrote: Wed Jul 28, 2021 8:13 am how about an tag to define parts of the sketch as "static" ( or ready/or done) ... so that the solver does not need to "solve" / touch this (tagged) part of the sketch any more ?
Interesting idea. I'm afraid I'm running out of good colors to display this :lol: .
C_h_o_p_i_n
Hi All,
well - how about - alternating green-yellow - in an analogy to the protective ground ( Schutzleiter ) in wiring.
Greetings,
Stefan
double coloured or dashed lines were already discussed before to distinguish construction or external geometry. But that seems currently to be impossible: either all or no dashes.
Locked
