[merged] PR #4935 Adding TechDrawTools to TechDraw WB
edi
Post by edi »
Adding first 5 tools taken from TechDrawTools.FCMacro to the master. The tools are:
- create circle center lines
- create hole thread side view and ground view
- create screw thread side view and ground view
The tools are documented in https://forum.freecadweb.org/viewtopic.php?f=35&t=59334.
Shalmeneser
Re: PR #4935 Adding TechDrawTools to TechDraw WB
Post by Shalmeneser »
8-)
domad
Post by domad »
yes, yes, yes...!
ragohix769
Post by ragohix769 »
edi wrote: Fri Jul 23, 2021 2:53 pm Adding first 5 tools taken from TechDrawTools.FCMacro to the master. The tools are:
You are a hero! 8-) 8-) 8-)
Great addition!
balrobs
Post by balrobs »
Hi @edi
Thank you for your great work!
I've compiled it on Linux without problems ... only this warning message:
[ 93%] Building CXX object src/Mod/TechDraw/App/CMakeFiles/TechDraw.dir/Cosmetic.cpp.o
/home/balrobs/Desktop/freecad-source/src/Mod/TechDraw/App/Cosmetic.cpp: In static member function ‘static std::pair<Base::Vector3<double>, Base::Vector3<double> > TechDraw::CenterLine::calcEndPoints2Lines(TechDraw::DrawViewPart*, std::vector<std::__cxx11::basic_string<char> >, int, double, double, double, double, bool)’:
/home/balrobs/Desktop/freecad-source/src/Mod/TechDraw/App/Cosmetic.cpp:999:75: warning: unused parameter ‘flip’ [-Wunused-parameter]
  999 |                                                       double rotate, bool flip)
[ 93%] Building CXX object src/Mod/TechDraw/App/CMakeFiles/TechDraw.dir/PropertyGeomFormatList.cpp.o
I can't evaluate if it's important and if it's related to your latest changes or not so I leave it to you.
Then testing your four tools I found some strange behaviors (forgive me if I got something wrong :oops: )
  • when in a view or section there is more then one circle (see view000 and section A-A) things are displayed misaligned
  • when using the "draw cosmetic hole thread ground view" tool (see view001) the cosmetic circle is drawn at the inside of the selected circle, the same as for the "draw cosmetic screw thread ground view (see view002)
  • when using the "draw cosmetic thread hole side view" tool (see section B-B) the cosmetic lines are drawn at the inside of the selected lines, the same as for the "draw cosmetic screw thread side view" tool (see section C-C)
BTW the tool tip text shows "draw cosmetic crew thread side view". Probably it should show "draw cosmetic screw thread side view"
Thank you again so much for all your efforts! Can't wait to see your tools merged to master.
test_01.FCStd
(29.11 KiB) Downloaded 102 times
edi
Post by edi »
@balrobs: Thank you for testing. It is a scaling problem. You use scale 0.5.
The origin of the coordinate system is allways in the center of the view. Because of an issue in my software all created figures are shrinked to the half size.
balrobs
Post by balrobs »
Hi @edi,
I'm happy you already localised the problem.
As soon as there will be a patch I will test again.
Thanks for lifting TD to a new level :D
