Newbie here - trying to set a post processor
LHC
Post by LHC »
Hi - I'm interested in learning the path workbench and have started by trying to set up a post processor, but all I got was a pile of python errors that I don't understand. Wondering if anyone can help me here. I have been using one of the recent weekly builds from the download page and have posted my info below, along with a screenshot of the errors. Thanks,
Lewis
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
  * A2plus 0.4.56a
  * Assembly4 0.12.0
  * Curves 0.4.4
  * Defeaturing
  * ExplodedAssembly
  * fasteners 0.3.44
  * fcgear 1.0.0
  * IconThemes
  * kicadStepUpMod 10.13.0
  * Manipulator 1.4.5
  * scripts
  * sheetmetal 0.2.58
  * VendorParts
GeneFC
Re: Newbie here - trying to set a post processor
Post by GeneFC »
LHC wrote: Sun Dec 04, 2022 7:09 pm
You need to use "refactored_grbl_post.py" instead of "grbl_post.py" for the latest versions of FreeCAD.
Gene
LHC
Post by LHC »
ok - I'll give that a try and report back - thanks !
LHC
Post by LHC »
I'm missing something extremely basic here I think. When I hover over the list of the post processors in the preferences I get this message -
" It doesn't seem there are any post processor scripts installed. Please add some into your macro directory and make sure the file name ends with _post.py"
There is a default selected post for linuxcnc in there but I am not sure it's right as I have not been able to find a linuxcnc file on my computer.
Do I need to download post processor scripts from somewhere or are there supposed to be a few that are already included somewhere ?
Sorry for the basic questions here.....
Thanks
Lewis
GeneFC
Post by GeneFC »
All the postprocessors are included with the precompiled Windows distributions. There are 29 of them included in FC 0.21.31155. They are located in the FC installation folder under /Mod/Path/Path/Post/scripts.
It is possible there are some permissions issues in your installation. Where is your FC installation located?
I only use the macro folder for custom postprocessors. The program should be able to draw from either the folder noted above or from the macro folder.
Gene
LHC
Post by LHC »
ok - I think I have it sorted. Yes, I have them all in the folder you referenced. I'm not sure why I am getting those errors I mentioned earlier, but if I make a small job and then edit the job and go to the output tab I can select the post processor from that and I'm good. I even found some online gcode simulator and loaded the file into it to prove to myself there really is gcode there that works ;)
So it looks like I am off to the races here and can start to learn the path workbench.
Thanks very much for your help (and patience) !
Lewis
luvtofish
Post by luvtofish »
LHC
Post by LHC »
luvtofish wrote: Fri Dec 09, 2022 2:43 pm See this post for those errors:
https://forum.freecadweb.org/viewtopic ... 5&t=74211
Thanks !
