Issue #7913 - Path not going to the bottom of a pocket
GeneFC
Re: Path not going to the bottom of a pocket
Post by GeneFC »
acp693 wrote: Wed Nov 30, 2022 11:43 am I've zipped the file and it now allows me to upload it.
Rather than re-zipping the FCStd (already zipped) file you can save with maximum compression. Setting in the Preferences.
Gene
acp693
Post by acp693 »
GeneFC wrote: Wed Nov 30, 2022 2:51 pm
Gene
Thanks Gene. It was already on Maximum compression level (level9!) Zipping brought it just under the limit.
acp693
Post by acp693 »
chrisb wrote: Wed Nov 30, 2022 12:26 pm Can you upload the sketch creating the B-splines? If I create one from the extrude, it has 475 DOF for one side. It has no controlpoints, but a degree of 15. Does it really have to be that complicated?
Hi Chris, after messing around with my original model, I extracted the original splines, made a face and then a solid and booleaned them from a block. File size is much lower. compared to my test block from before, I'd used a facebinder to extract the bottom of the pocket from my original model and then extruded and minused that from a block - maybe that was the cause of the extreme amount of data. The original splines are much simpler.
However, With this new test scenario, I can't create any path at all, no matter what depth settings I use. I get the following error message:
16:21:41 PocketShape.ERROR: Pocket does not support shape Model-Cut001.Face11
16:21:41 Geom.INFO: Zero working area to process. Check your selection and settings.
I'm a bit at a loss as what to do now.
Version: 0.21.31109 (Git)
Hash: c23ee7ad88433a0f00e84afae0a62fe738be0c09
  * BIM 2021.12.0
  * CurvedShapes 1.0.4
  * Curves 0.5.3
  * FeedsAndSpeeds 0.4.0
  * Marz 0.0.26-alpha
  * Silk 1.0.0
TestPocket5.FCStd
(292.52 KiB) Downloaded 12 times
I have created a simple test file. It contains two pockets.
The upper one was made with a B-Spline, the lower with an arc.
The B-spline based pocket fails, the arc based succeeds.
OS: macOS 10.16
Version: 0.21.31035 (Git)
Hash: c8074a972ee233d303e50e5d525aecae09c1cd04
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * fcgear 1.0.0
  * fasteners 0.4.16
  * sheetmetal 0.2.57
  * ExplodedAssembly
  * Curves 0.6.1
BSplinePocket.FCStd
(33.78 KiB) Downloaded 11 times
acp693 wrote: Wed Nov 30, 2022 11:43 am I don't know how to submit a bug report.
You need a Github account and then you create a ticket here: https://github.com/FreeCAD/FreeCAD/issues.
acp693
Post by acp693 »
It looks to me like the upper one fails and not the lower one? The path on the upper one doesn't reach the bottom of the pocket?
chrisb wrote: Wed Nov 30, 2022 4:41 pm The lower one was made with a B-Spline, the upper with an arc.
Thank you for going to this effort, I appreciate it greatly
acp693
Post by acp693 »
acp693 wrote: Wed Nov 30, 2022 5:11 pm It looks to me like the upper one fails and not the lower one? The path on the upper one doesn't reach the bottom of the pocket?
I have corrected my post above. I had forgotten to save before I uploaded the file.
acp693
Post by acp693 »
Hi Chris, your post is still wrong. The upper pocket is made with a spline as far as I can see and the lower one with an arc. The upper pocket is the one that fails
acp693 wrote: Wed Nov 30, 2022 6:05 pm Hi Chris, your post is still wrong. The upper pocket is made with a spline as far as I can see and the lower one with an arc. The upper pocket is the one that fails
Thanks for correcting me again :oops: . I may explain what had happened: I started with the B-spline below. Then I thought it might be slightly clearer if I had the wrong one on top, because in the Job it is above the right one ... And then I messed it all up.
