Post-processor for Shapeoko Pro
vchov
Post by vchov »
Hi, I'm used to using Carbide Create to generate g-code for my local makerspace's Shapeoko Pro CNC router, but would like to use FreeCAD (or some other cross-platform FOSS CAM package if that's easier, since I want first-class Linux support). How do I go about looking for one?
I've heard of people using Fusion 360 (see example postprocessor here: https://cam.autodesk.com/hsmposts?p=carbide3d), and it looks like it's written in Javascript, while FreeCAD post-processors seem to be written in Python. Do I need to write my own, by trying to translate the Javascript PP from Fusion to Python?
Thanks a lot for the help!
In case the link breaks, here's the Fusion post-processor at the time of writing:
  Copyright (C) 2012-2022 by Autodesk, Inc.
  All rights reserved.
  Carbide 3D Grbl post processor configuration.
  $Revision: 43777 ff938d4771883144ce8a48c0567d8814618df70b $
  $Date: 2022-04-21 16:47:31 $
  FORKID {D897E9AA-349A-4011-AA01-06B6CCC181EB}
description = "Carbide 3D (Grbl)";
vendor = "Carbide 3D";
vendorUrl = "http://www.carbide3d.com";
legal = "Copyright (C) 2012-2022 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 45702;
longDescription = "Generic milling post for Carbide 3D (Grbl).";
extension = "nc";
setCodePage("ascii");
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.25, MM);
minimumCircularRadius = spatial(0.1, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
  writeMachine: {
    title      : "Write machine",
    description: "Output the machine settings in the header of the code.",
    group      : "formats",
    type       : "boolean",
    value      : true,
    scope      : "post"
  writeTools: {
    title      : "Write tool list",
    description: "Output a tool list in the header of the code.",
    group      : "formats",
    type       : "boolean",
    value      : true,
    scope      : "post"
  showSequenceNumbers: {
    title      : "Use sequence numbers",
    description: "'Yes' outputs sequence numbers on each block, 'Only on tool change' outputs sequence numbers on tool change blocks only, and 'No' disables the output of sequence numbers.",
    group      : "formats",
    type       : "enum",
    values     : [
      {title:"Yes", id:"true"},
      {title:"No", id:"false"},
      {title:"Only on tool change", id:"toolChange"}
    value: "false",
    scope: "post"
  sequenceNumberStart: {
    title      : "Start sequence number",
    description: "The number at which to start the sequence numbers.",
    group      : "formats",
    type       : "integer",
    value      : 10,
    scope      : "post"
  sequenceNumberIncrement: {
    title      : "Sequence number increment",
    description: "The amount by which the sequence number is incremented by in each block.",
    group      : "formats",
    type       : "integer",
    value      : 1,
    scope      : "post"
  separateWordsWithSpace: {
    title      : "Separate words with space",
    description: "Adds spaces between words if 'yes' is selected.",
    group      : "formats",
    type       : "boolean",
    value      : true,
    scope      : "post"
  safePositionMethod: {
    title      : "Safe Retracts",
    description: "Select your desired retract option. 'Clearance Height' retracts to the operation clearance height.",
    group      : "homePositions",
    type       : "enum",
    values     : [
      {title:"G28", id:"G28"},
      // {title:"G53", id: "G53"},
      {title:"Clearance Height", id:"clearanceHeight"}
    value: "G28",
    scope: "post"
// wcs definiton
wcsDefinitions = {
  useZeroOffset: false,
  wcs          : [
    {name:"Standard", format:"G", range:[54, 59]}
var numberOfToolSlots = 9999;
var singleLineCoolant = false; // specifies to output multiple coolant codes in one line rather than in separate lines
// samples:
// {id: COOLANT_THROUGH_TOOL, on: 88, off: 89}
// {id: COOLANT_THROUGH_TOOL, on: [8, 88], off: [9, 89]}
// {id: COOLANT_THROUGH_TOOL, on: "M88 P3 (myComment)", off: "M89"}
var coolants = [
  {id:COOLANT_FLOOD, on:7},
  {id:COOLANT_MIST},
  {id:COOLANT_THROUGH_TOOL},
  {id:COOLANT_AIR},
  {id:COOLANT_AIR_THROUGH_TOOL},
  {id:COOLANT_SUCTION},
  {id:COOLANT_FLOOD_MIST},
  {id:COOLANT_FLOOD_THROUGH_TOOL},
  {id:COOLANT_OFF, off:9}
var gFormat = createFormat({prefix:"G", decimals:0});
var mFormat = createFormat({prefix:"M", decimals:0});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4)});
var feedFormat = createFormat({decimals:(unit == MM ? 2 : 3)});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-1000
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({onchange:function() {retracted = false;}, prefix:"Z"}, xyzFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var WARNING_WORK_OFFSET = 0;
// collected state
var sequenceNumber;
var forceSpindleSpeed = false;
var currentWorkOffset;
var retracted = false; // specifies that the tool has been retracted to the safe plane
  Writes the specified block.
function writeBlock() {
  var text = formatWords(arguments);
  if (!text) {
    return;
  if (getProperty("showSequenceNumbers") == "true") {
    writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += getProperty("sequenceNumberIncrement");
  } else {
    writeWords(arguments);
function formatComment(text) {
  return "(" + String(text).replace(/[()]/g, "") + ")";
  Writes the specified block - used for tool changes only.
function writeToolBlock() {
  var show = getProperty("showSequenceNumbers");
  setProperty("showSequenceNumbers", (show == "true" || show == "toolChange") ? "true" : "false");
  writeBlock(arguments);
  setProperty("showSequenceNumbers", show);
  Output a comment.
function writeComment(text) {
  writeln(formatComment(text));
function onOpen() {
  if (!getProperty("separateWordsWithSpace")) {
    setWordSeparator("");
  sequenceNumber = getProperty("sequenceNumberStart");
  writeln("%");
  if (programName) {
    writeComment(programName);
  if (programComment) {
    writeComment(programComment);
  // dump machine configuration
  var vendor = machineConfiguration.getVendor();
  var model = machineConfiguration.getModel();
  var description = machineConfiguration.getDescription();
  if (getProperty("writeMachine") && (vendor || model || description)) {
    writeComment(localize("Machine"));
    if (vendor) {
      writeComment("  " + localize("vendor") + ": " + vendor);
    if (model) {
      writeComment("  " + localize("model") + ": " + model);
    if (description) {
      writeComment("  " + localize("description") + ": "  + description);
  // dump tool information
  if (getProperty("writeTools")) {
    var zRanges = {};
    if (is3D()) {
      var numberOfSections = getNumberOfSections();
      for (var i = 0; i < numberOfSections; ++i) {
        var section = getSection(i);
        var zRange = section.getGlobalZRange();
        var tool = section.getTool();
        if (zRanges[tool.number]) {
          zRanges[tool.number].expandToRange(zRange);
        } else {
          zRanges[tool.number] = zRange;
    var tools = getToolTable();
    if (tools.getNumberOfTools() > 0) {
      for (var i = 0; i < tools.getNumberOfTools(); ++i) {
        var tool = tools.getTool(i);
        var comment = "T" + toolFormat.format(tool.number) + "  " +
          "D=" + xyzFormat.format(tool.diameter) + " " +
          localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
        if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
          comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
          comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
        comment += " - " + getToolTypeName(tool.type);
        writeComment(comment);
  if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
    for (var i = 0; i < getNumberOfSections(); ++i) {
      if (getSection(i).workOffset > 0) {
        error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
        return;
  // absolute coordinates and feed per min
  writeBlock(gAbsIncModal.format(90));
  writeBlock(gPlaneModal.format(17));
  switch (unit) {
  case IN:
    writeBlock(gUnitModal.format(20));
    break;
  case MM:
    writeBlock(gUnitModal.format(21));
    break;
function onComment(message) {
  writeComment(message);
/** Force output of X, Y, and Z. */
function forceXYZ() {
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
/** Force output of X, Y, Z, and F on next output. */
function forceAny() {
  forceXYZ();
  feedOutput.reset();
function isProbeOperation() {
  return hasParameter("operation-strategy") && (getParameter("operation-strategy") == "probe");
function onSection() {
  var insertToolCall = isFirstSection() ||
    currentSection.getForceToolChange && currentSection.getForceToolChange() ||
    (tool.number != getPreviousSection().getTool().number);
  retracted = false;
  var newWorkOffset = isFirstSection() ||
    (getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
  var newWorkPlane = isFirstSection() ||
    !isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis()) ||
    (currentSection.isOptimizedForMachine() && getPreviousSection().isOptimizedForMachine() &&
      Vector.diff(getPreviousSection().getFinalToolAxisABC(), currentSection.getInitialToolAxisABC()).length > 1e-4) ||
    (!machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) ||
    (!getPreviousSection().isMultiAxis() && currentSection.isMultiAxis() ||
      getPreviousSection().isMultiAxis() && !currentSection.isMultiAxis()); // force newWorkPlane between indexing and simultaneous operations
  if (insertToolCall || newWorkOffset || newWorkPlane) {
    // stop spindle before retract during tool change
    if (insertToolCall && !isFirstSection()) {
      onCommand(COMMAND_STOP_SPINDLE);
    // retract to safe plane
    writeRetract(Z);
    zOutput.reset();
  writeln("");
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment) {
  if (insertToolCall) {
    setCoolant(COOLANT_OFF);
    if (tool.number > numberOfToolSlots) {
      warning(localize("Tool number exceeds maximum value."));
    writeToolBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
    if (tool.comment) {
      writeComment(tool.comment);
    var showToolZMin = false;
    if (showToolZMin) {
      if (is3D()) {
        var zRange = currentSection.getGlobalZRange();
        var number = tool.number;
        for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
          if (section.getTool().number != number) {
            break;
          zRange.expandToRange(section.getGlobalZRange());
        writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
  var spindleChanged = tool.type != TOOL_PROBE &&
    (insertToolCall || forceSpindleSpeed || isFirstSection() ||
    (rpmFormat.areDifferent(spindleSpeed, sOutput.getCurrent())) ||
    (tool.clockwise != getPreviousSection().getTool().clockwise));
  if (spindleChanged) {
    if (spindleSpeed < 1) {
      error(localize("Spindle speed out of range."));
    if (spindleSpeed > 99999) {
      warning(localize("Spindle speed exceeds maximum value."));
    writeBlock(
      sOutput.format(spindleSpeed), mFormat.format(tool.clockwise ? 3 : 4)
  // wcs
  if (insertToolCall) { // force work offset when changing tool
    currentWorkOffset = undefined;
  if (currentSection.workOffset != currentWorkOffset) {
    writeBlock(currentSection.wcs);
    currentWorkOffset = currentSection.workOffset;
  forceXYZ();
  { // pure 3D
    var remaining = currentSection.workPlane;
    if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
      error(localize("Tool orientation is not supported."));
      return;
    setRotation(remaining);
  // set coolant after we have positioned at Z
  setCoolant(tool.coolant);
  forceAny();
  var initialPosition = getFramePosition(currentSection.getInitialPosition());
  if (!retracted && !insertToolCall) {
    if (getCurrentPosition().z < initialPosition.z) {
      writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
  if (insertToolCall || retracted) {
    var lengthOffset = tool.lengthOffset;
    if (lengthOffset > numberOfToolSlots) {
      error(localize("Length offset out of range."));
      return;
    if (!machineConfiguration.isHeadConfiguration()) {
      writeBlock(
        gAbsIncModal.format(90),
        gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
    } else {
      writeBlock(
        yOutput.format(initialPosition.y),
  } else {
    writeBlock(
function onDwell(seconds) {
  if (seconds > 99999.999) {
    warning(localize("Dwelling time is out of range."));
  seconds = clamp(0.001, seconds, 99999.999);
  writeBlock(gFormat.format(4), "P" + secFormat.format(seconds));
function onSpindleSpeed(spindleSpeed) {
  writeBlock(sOutput.format(spindleSpeed));
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
  pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    if (pendingRadiusCompensation >= 0) {
      error(localize("Radius compensation mode cannot be changed at rapid traversal."));
      return;
    writeBlock(gMotionModal.format(0), x, y, z);
    feedOutput.reset();
function onLinear(_x, _y, _z, feed) {
  // at least one axis is required
    // ensure that we end at desired position when compensation is turned off
    xOutput.reset();
    yOutput.reset();
  var f = feedOutput.format(feed);
  if (x || y || z) {
      error(localize("Radius compensation mode is not supported."));
      return;
    } else {
      writeBlock(gMotionModal.format(1), x, y, z, f);
  } else if (f) {
    if (getNextRecord().isMotion()) { // try not to output feed without motion
      feedOutput.reset(); // force feed on next line
    } else {
      writeBlock(gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
  error(localize("Multi-axis motion is not supported."));
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
/** Adjust final point to lie exactly on circle. */
function CircularData(_plane, _center, _end) {
  // use Output variables, since last point could have been adjusted if previous move was circular
  var start = new Vector(xOutput.getCurrent(), yOutput.getCurrent(), zOutput.getCurrent());
  var saveStart = new Vector(start.x, start.y, start.z);
  var center = new Vector(
    xyzFormat.getResultingValue(_center.x),
    xyzFormat.getResultingValue(_center.y),
    xyzFormat.getResultingValue(_center.z)
  var end = new Vector(_end.x, _end.y, _end.z);
  switch (_plane) {
  case PLANE_XY:
    start.setZ(center.z);
    end.setZ(center.z);
    break;
  case PLANE_ZX:
    start.setY(center.y);
    end.setY(center.y);
    break;
  case PLANE_YZ:
    start.setX(center.x);
    end.setX(center.x);
    break;
  default:
    this.center = new Vector(_center.x, _center.y, _center.z);
    this.start = new Vector(start.x, start.y, start.z);
    this.end = new Vector(_end.x, _end.y, _end.z);
    this.offset = Vector.diff(center, start);
    this.radius = this.offset.length;
    xyzFormat.getResultingValue(start.x),
    xyzFormat.getResultingValue(start.y),
    xyzFormat.getResultingValue(start.z)
  var temp = Vector.diff(center, start);
  this.offset = new Vector(
    xyzFormat.getResultingValue(temp.x),
    xyzFormat.getResultingValue(temp.y),
    xyzFormat.getResultingValue(temp.z)
  this.center = Vector.sum(this.start, this.offset);
  temp = Vector.diff(end, center).normalized;
    xyzFormat.getResultingValue(this.center.x + temp.x * this.radius),
    xyzFormat.getResultingValue(this.center.y + temp.y * this.radius),
    xyzFormat.getResultingValue(this.center.z + temp.z * this.radius)
  switch (_plane) {
  case PLANE_XY:
    this.start.setZ(saveStart.z);
    this.end.setZ(_end.z);
    this.offset.setZ(0);
    break;
  case PLANE_ZX:
    this.start.setY(saveStart.y);
    this.end.setY(_end.y);
    this.offset.setY(0);
    break;
  case PLANE_YZ:
    this.start.setX(saveStart.x);
    this.end.setX(_end.x);
    this.offset.setX(0);
    break;
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
  // one of X/Y and I/J are required and likewise
    error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
    return;
  circle = new CircularData(getCircularPlane(), new Vector(cx, cy, cz), new Vector(x, y, z));
  if (isFullCircle()) {
    if (isHelical()) {
      linearize(tolerance);
      return;
    // TAG: are 360deg arcs supported
    switch (getCircularPlane()) {
    case PLANE_XY:
      writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(circle.end.x), iOutput.format(circle.offset.x, 0), jOutput.format(circle.offset.y, 0), feedOutput.format(feed));
      break;
    case PLANE_ZX:
      writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), zOutput.format(circle.end.z), iOutput.format(circle.offset.x, 0), kOutput.format(circle.offset.z, 0), feedOutput.format(feed));
      break;
    case PLANE_YZ:
      writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), yOutput.format(circle.end.y), jOutput.format(circle.offset.y, 0), kOutput.format(circle.offset.z, 0), feedOutput.format(feed));
      break;
    default:
  } else {
    case PLANE_XY:
        xOutput.format(circle.end.x), yOutput.format(circle.end.y), zOutput.format(circle.end.z),
      break;
    case PLANE_ZX:
      break;
    case PLANE_YZ:
      break;
    default:
var currentCoolantMode = COOLANT_OFF;
var coolantOff = undefined;
var forceCoolant = false;
function setCoolant(coolant) {
  var coolantCodes = getCoolantCodes(coolant);
  if (Array.isArray(coolantCodes)) {
    if (singleLineCoolant) {
      writeBlock(coolantCodes.join(getWordSeparator()));
    } else {
      for (var c in coolantCodes) {
        writeBlock(coolantCodes[c]);
    return undefined;
  return coolantCodes;
function getCoolantCodes(coolant) {
  var multipleCoolantBlocks = new Array(); // create a formatted array to be passed into the outputted line
  if (!coolants) {
    error(localize("Coolants have not been defined."));
  if (tool.type == TOOL_PROBE) { // avoid coolant output for probing
    coolant = COOLANT_OFF;
  if (coolant == currentCoolantMode && (!forceCoolant || coolant == COOLANT_OFF)) {
    return undefined; // coolant is already active
  if ((coolant != COOLANT_OFF) && (currentCoolantMode != COOLANT_OFF) && (coolantOff != undefined) && !forceCoolant) {
    if (Array.isArray(coolantOff)) {
      for (var i in coolantOff) {
        multipleCoolantBlocks.push(coolantOff[i]);
    } else {
      multipleCoolantBlocks.push(coolantOff);
  var m;
  var coolantCodes = {};
  for (var c in coolants) { // find required coolant codes into the coolants array
    if (coolants[c].id == coolant) {
      coolantCodes.on = coolants[c].on;
      if (coolants[c].off != undefined) {
        coolantCodes.off = coolants[c].off;
        break;
      } else {
        for (var i in coolants) {
          if (coolants[i].id == COOLANT_OFF) {
            coolantCodes.off = coolants[i].off;
            break;
  if (coolant == COOLANT_OFF) {
    m = !coolantOff ? coolantCodes.off : coolantOff; // use the default coolant off command when an 'off' value is not specified
  } else {
    coolantOff = coolantCodes.off;
    m = coolantCodes.on;
  if (!m) {
    onUnsupportedCoolant(coolant);
    m = 9;
  } else {
    if (Array.isArray(m)) {
      for (var i in m) {
        multipleCoolantBlocks.push(m[i]);
    } else {
      multipleCoolantBlocks.push(m);
    currentCoolantMode = coolant;
    for (var i in multipleCoolantBlocks) {
      if (typeof multipleCoolantBlocks[i] == "number") {
        multipleCoolantBlocks[i] = mFormat.format(multipleCoolantBlocks[i]);
    return multipleCoolantBlocks; // return the single formatted coolant value
  return undefined;
var mapCommand = {
  COMMAND_STOP                    : 0,
  COMMAND_END                     : 2,
  COMMAND_SPINDLE_CLOCKWISE       : 3,
  COMMAND_SPINDLE_COUNTERCLOCKWISE: 4,
  COMMAND_STOP_SPINDLE            : 5
function onCommand(command) {
  switch (command) {
  case COMMAND_STOP:
    writeBlock(mFormat.format(0));
    forceSpindleSpeed = true;
    forceCoolant = true;
    return;
  case COMMAND_START_SPINDLE:
    onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    return;
  case COMMAND_LOCK_MULTI_AXIS:
    return;
  case COMMAND_UNLOCK_MULTI_AXIS:
    return;
  case COMMAND_BREAK_CONTROL:
    return;
  case COMMAND_TOOL_MEASURE:
    return;
  var stringId = getCommandStringId(command);
  var mcode = mapCommand[stringId];
  if (mcode != undefined) {
    writeBlock(mFormat.format(mcode));
  } else {
    onUnsupportedCommand(command);
function onSectionEnd() {
  if (!isLastSection() && (getNextSection().getTool().coolant != tool.coolant)) {
  forceAny();
/** Output block to do safe retract and/or move to home position. */
function writeRetract() {
  var words = []; // store all retracted axes in an array
  var retractAxes = new Array(false, false, false);
  var method = getProperty("safePositionMethod");
  if (method == "clearanceHeight") {
    if (!is3D()) {
      error(localize("Safe retract option 'Clearance Height' is only supported when all operations are along the setup Z-axis."));
    return;
  validate(arguments.length != 0, "No axis specified for writeRetract().");
  for (i in arguments) {
    retractAxes[arguments[i]] = true;
  if ((retractAxes[0] || retractAxes[1]) && !retracted) { // retract Z first before moving to X/Y home
    error(localize("Retracting in X/Y is not possible without being retracted in Z."));
    return;
  // special conditions
  if (retractAxes[2]) { // Z doesn't use G53
    method = "G28";
  // define home positions
  var _xHome;
  var _yHome;
  var _zHome;
  if (method == "G28") {
    _xHome = toPreciseUnit(0, MM);
    _yHome = toPreciseUnit(0, MM);
    _zHome = toPreciseUnit(0, MM);
  } else {
    _xHome = machineConfiguration.hasHomePositionX() ? machineConfiguration.getHomePositionX() : toPreciseUnit(0, MM);
    _yHome = machineConfiguration.hasHomePositionY() ? machineConfiguration.getHomePositionY() : toPreciseUnit(0, MM);
    _zHome = machineConfiguration.getRetractPlane() != 0 ? machineConfiguration.getRetractPlane() : toPreciseUnit(0, MM);
  for (var i = 0; i < arguments.length; ++i) {
    switch (arguments[i]) {
    case X:
      words.push("X" + xyzFormat.format(_xHome));
      xOutput.reset();
      break;
    case Y:
      words.push("Y" + xyzFormat.format(_yHome));
      yOutput.reset();
      break;
    case Z:
      words.push("Z" + xyzFormat.format(_zHome));
      zOutput.reset();
      retracted = true;
      break;
    default:
      error(localize("Unsupported axis specified for writeRetract()."));
      return;
  if (words.length > 0) {
    switch (method) {
    case "G28":
      gAbsIncModal.reset();
      writeBlock(gFormat.format(28), gAbsIncModal.format(91), words);
      break;
    case "G53":
      writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), words);
      break;
    default:
      error(localize("Unsupported safe position method."));
      return;
function onClose() {
  writeRetract(Z); // retract
  writeRetract(X, Y);
  onImpliedCommand(COMMAND_END);
  onImpliedCommand(COMMAND_STOP_SPINDLE);
  writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
  writeln("%");
function setProperty(property, value) {
  properties[property].current = value;
The Software Engineer's Credo: We do this not because it was easy, but because we thought it would be easy. :?
bmsaus4ax
Re: Post-processor for Shapeoko Pro
Post by bmsaus4ax »
vchov wrote: Fri Nov 25, 2022 5:04 pm Hi, I'm used to using Carbide Create to generate g-code for my local makerspace's Shapeoko Pro CNC router, but would like to use FreeCAD (or some other cross-platform FOSS CAM package if that's easier, since I want first-class Linux support). How do I go about looking for one?
FreeCAD Path has a grbl post processor which would seem to be what the Fusion one is :- "Carbide 3D Grbl post processor configuration." -: from the code included.
Post out with that and see if it is correct for your machine, should be easy to check since you can produce code from both sources and compare.
vchov
Post by vchov »
Okay, thanks! So you're suggesting I compare the output when generating g-code from Carbide Create, vs from FreeCAD using a GRBL post-processor?
I think you mean that Carbide's post-processor uses a dialect of g-code called GRBL, and so a generic GRBL post-processor should produce a mostly-identical output?
I can probably draw a simple rectangular prism, like I'm just cutting a perimeter around a sheet of plywood as an easy model to compare across applications.
Should I try to draw something more complicated, or is there a generally-recommended shape that's used for comparing post-processors?
bmsaus4ax
Post by bmsaus4ax »
vchov wrote: Sat Nov 26, 2022 3:06 am Okay, thanks! So you're suggesting I compare the output when generating g-code from Carbide Create, vs from FreeCAD using a GRBL post-processor?
Yes
GRBL is a code interpreter / machine controller so you would expect the code to be kept consistent across all it's implementations.
To cover the most possibilities it would good to include as much variety as you expect to use.
Speeds and feeds, profiles, arcs, drilling (drilling can expose different coding styles), coolant , fixture (G54 etc ). and tool change.
vchov
Post by vchov »
Okay, thanks! I'll give that a try and post back if I run into issues. If I write a post-processor for the Shapeoko Pro, is it worth it to make a Github repo for it, or is there another recommended way of sharing it for other FreeCAD users?
You can clone FreeCAD repo and create the postprocessor directly in the postprocessor directory: FreeCAD/Mod/Path/Pathscripts/Post
See:
Path_Post
Path_Postprocessor_Customization
spanner888
Post by spanner888 »
Kunda1 wrote: Tue Nov 29, 2022 6:35 pm You can clone FreeCAD repo and create the postprocessor directly in the postprocessor directory: FreeCAD/Mod/Path/Pathscripts/Post
See:
Path_Post
2nd link above says: "can be placed in your FreeCAD macro directory. " This avoids any need to clone/build FreeCAD and also means that your postprocessor will not get overwritten by any updates. This works nicely.
spanner888 wrote: Tue Nov 29, 2022 10:06 pm 2nd link above says: "can be placed in your FreeCAD macro directory. " This avoids any need to clone/build FreeCAD and also means that your postprocessor will not get overwritten by any updates. This works nicely.
Agreed but it would be nice if changes get sent upstream as well, right?
spanner888
Kunda1 wrote: Wed Nov 30, 2022 12:10 am
Yep, 100%.
