The toolpath is fine as far as accuracy but has way too much redundancy cutting the upper layer surface contours 3 times over while working down thru the cut depths.
Is there a way to set this up to eliminating the overcuts?
I have tried using the optimize step over transitions but it just cuts below the specified cut depth. this might work with an additional finishing toolpath single pass but its an awkward solution?
This is by no means an impasse but it would be nice to find a workaround.
thanks again for all the help. dkw
The toolpath file in question is AT17 right inner face zzmp 50
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.2
* Curves 0.3.0
* Help 1.0.3
* ocl.pyd
