Pocket operation does not work correctly
memfis
Post by memfis »
OS: Arch Linux (GNOME/gnome-xorg)
Version: 0.21.30305 (Git) AppImage
Hash: 5ffc2e10b69971e2cdcd798c4deacf44d407fd77
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
  * Lithophane
As soon as you select Use Outline = not good at all
Снимок экрана от 2022-09-11 00-12-46.jpg (174.8 KiB) Viewed 942 times
деталь.FCStd
(89.31 KiB) Downloaded 17 times
Снимок экрана от 2022-09-11 00-11-40.jpg (246.6 KiB) Viewed 944 times
GeneFC
Re: Pocket operation does not work correctly
Post by GeneFC »
I think it is working as designed. Use outline means the inside will be ignored. Uncheck that box and the pattern looks correct.
Gene
memfis
Post by memfis »
? вот те на.
I'm afraid there's a mistake here. Using this option involves machining the entire surface of the slot, not excluding holes and deeper areas. And in this case the option completely destroys the ledge, i.e. the borders of the pocket
GeneFC
Post by GeneFC »
I guess I am missing something.
Why use that option if it is not what you want?
Gene
memfis
Post by memfis »
are we talking about the same thing? about the Pocket operation in the FC program? if yes, then on the receiver of this part, where the milling should process the selected planes - in the first screenshot in green-marsh color, then the choice of operations is not very wide. Namely, Pocket.
This option is chosen so that the program does not bypass the holes, because bypassing the holes is simply not necessary, requiring time and lines of code, and then additional grinding.
Or I am missing something.
GeneFC
Post by GeneFC »
I did not create this code, so I am not certain what is intended. However, it seems to work according to the description in the wiki.
Use Outline not checked.JPG (27.78 KiB) Viewed 767 times
Use Outline checked.JPG (49.55 KiB) Viewed 767 times
  * FeedsAndSpeeds 0.4.0
  * FeedsAndSpeeds-master.zip
  * Help 1.0.3
  * offline-documentation
Gene
Russ4262
Post by Russ4262 »
Evening.
Per OP, the `Use Outline` feature would benefit from an improvement. It would be beneficial to add the option and/or ability to differentiate holes that are pockets (which can safely be cleared using this feature) from holes that are positive protrusions above the selected face (regions to be avoided by cutter when this option is enabled). I think that the MillFace operation has this type of differentiation available related to avoiding raised areas.
Perhaps a feature request is the solution for such an improvement here.
Thanks for identifying this issue and reporting it.
Have a great week.
Russell
mlampert
Post by mlampert »
memfis wrote: Sun Sep 11, 2022 4:14 pm Or I am missing something.
No, you are not missing anything - this works exactly as designed and does exactly what it is being asked to do, namely use the outline of the selected shape and create a pocket on that.
