Bug #7468 - Test PathTests.TestPathDrillable.TestPathDrillable fails on s390x
coldtobi
Post by coldtobi »
I'm one of the people looking after FreeCAD in Debian, I've encountered a test suite error in the TestPathDrillable testsuite on the s390x Architecture.
The other architectures seems to be fine, so I'm quite puzzled about the reason behind.
s390x is for Debian a release architecture, so this failure currently prevents freecad to migrate to "testing", the staging area for the next release of Debian.
The failure happens on the Debian CI, the full log for (the failing) s390x can be found here: https://ci.debian.net/data/autopkgtest/ ... 237/log.gz, here the excerpt of the failing test:
FAIL: test10 (PathTests.TestPathDrillable.TestPathDrillable)
Test isDrillable
  File "/usr/share/freecad/Mod/Path/PathTests/TestPathDrillable.py", line 78, in test10
    self.assertTrue(drillableLib.isDrillable(self.obj.Shape, candidate))
AssertionError: False is not true
FAIL: test20 (PathTests.TestPathDrillable.TestPathDrillable)
Test getDrillableTargets
  File "/usr/share/freecad/Mod/Path/PathTests/TestPathDrillable.py", line 305, in test20
    self.assertEqual(len(results), 20)
AssertionError: 21 != 20
Ran 736 tests in 46.072s
FAILED (failures=2)
As said, I have no idea where to start looking to pin point the problem, let me know if I can somehow provide more information.
Reason: Added GH ticket number to thread title
Re: Test PathTests.TestPathDrillable.TestPathDrillable fails on s390x
What revision are you pulling (HEAD ?)
Is there a list of dependencies you can post ?
freecad --version --verbose
or paste the About info
sliptonic
Post by sliptonic »
coldtobi wrote: Fri Sep 09, 2022 2:05 pm Hi,
Thanks for working on this.
The unittest is testing the functionality of the drillablelib module. Basically there's a function that finds holes in a shape that can be drilled on a CNC machine. It also can evaluate a single candidate hole.
Drillable in this context means that the hole is cylindrical and aligned with the Z axis.
It first loads the test file (/Mod/Path/PathTests/Drilling_1.FCStd in the install directory)
This particular test is evaluating the cylindrical wall shown below which is definitely drillable. For some reason, it's reporting as not drillable on that architecture.
There's somethings you can do to get more info.
Edit the File /Mod/Path/PathScripts/drillableLib.py
set line 7 to True and rerun the test. The PathLog statements should tell us which of the attributes is failing.
You can run just this one test from the command line like this
FreeCADCmd -t TestPathApp.TestPathDrillable.test10
You can also start FreeCAD and open the test file. Then run this macro
from PathScripts import drillableLib as dl
from importlib import reload
reload(dl)
obj = doc.getObject("Body")
s = obj.getSubObject("Face30")
if dl.isDrillable(obj.Shape, s):
    print("drillable")
else:
    print("not drillable")
vm4dim
Post by vm4dim »
Which is correct 20 or 21?
I'm confused. :shock:
mfro
Post by mfro »
Although off-topic, I would be eager to know if there is anybody using FreeCAD on an s390/System Z?
Cheers,
Markus
coldtobi
Post by coldtobi »
Kunda1 wrote: Fri Sep 09, 2022 5:33 pm What revision are you pulling (HEAD ?)
FreeCAD 0.20.1 Revision:
Library versions:
boost    1_74
Coin3D   4.0.0
Eigen3   3.4.0
OCC      7.6.3
Qt       5.15.4
Python   3.10.7
PySide   5.15.2
shiboken 5.15.2
VTK      9.1.0
xerces-c 3.2.3
Many thanks for the hints/instructions!
I've tried to load that file on the s390x porterbox I have access to, /running FreeCAD
in a VNC server), and it does not load the file: Freecad runs out of memory while and gets killed
by the OOM killwe while trying to load the file (the porter box has 4GiB RAM/4GiB Swap configures)
sliptonic wrote: Fri Sep 09, 2022 8:10 pm There's somethings you can do to get more info.
Here's the output: (I've snipped the "progress indicator" when loading to keep it brief, marked with "(…)"
The command issues was:
FreeCADCmd -t TestPathApp.TestPathDrillable.test10 >~/test10.log 2>&1
Test isDrillable ... FAIL
Test isDrillable
  File "/home/tobi/freecad_sid_s390x/freecad-0.20.1+dfsg1/debian/build-py3/Mod/Path/PathTests/TestPathDrillable.py", line 78, in test10
Ran 1 test in 0.125s
FAILED (failures=1)
FreeCAD 0.20.1, Libs: 0.20.1R
(c) Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
Importing project files......
						(100 %)
Postprocessing......
						(100 %)
drillableLib.DEBUG: (223) - obj: <Solid object at 0x2aa2f126190> candidate: <Vertex object at 0x2aa2f11b800> tooldiameter None vector Vector (0.0, 0.0, 1.0)
drillableLib.DEBUG: (223) - obj: <Solid object at 0x2aa2f11b800> candidate: <Face object at 0x2aa2f126190> tooldiameter None vector Vector (0.0, 0.0, 1.0)
drillableLib.DEBUG: (50) -
 match tool diameter False
 match vector True
drillableLib(105).isDrillableCylinder(candidate is a blind hole)
drillableLib.DEBUG: (264) - vector angle: 180.0
drillableLib(111).isDrillableCylinder(False)
tobi
sliptonic
Post by sliptonic »
Very strange.
First, it's detecting that the hole is blind. It's not. I'm seeing this on my machine also and I don't think it's the problem.
It's failing because the hole 'direction' is wrong.
On my machine, it's detecting the angle of the hole is 0.0 degrees so it's drillable from the top, even if it's blind.
Your trace shows that it's detecting the hole as 180 degrees so not drillable. I don't understand.
There are significant differences between versions. Notably Python and OCC. If I had to venture a guess, I'd say it's OCC related. I'll try to investigate further.
OS: Linux Mint 20 (i3/i3)
Version: 0.21.30345 (Git)
Build type: Unknown
Hash: f42a47aa0fd8c4f34ef63c185d9f29b9b6e84737
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
  * Assembly4 0.12.3
  * Behave-Dark-Colors 0.1.1
  * 3DfindIT 1.2.0
  * sheetmetal 0.2.52
  * FeedsAndSpeeds
  * ExtremeProDark 1.0.4
  * FeedsAndSpeeds.bak
  * Dracula 0.0.2
sliptonic
Post by sliptonic »
Forget the blind-hole thing. That's a red-herring. Just a misplaced debug statement which I'll fix
Re: Bug #7468 - Test PathTests.TestPathDrillable.TestPathDrillable fails on s390x
Op opened issue #7468
