- Export a job template with OpDefault StepOver
- Create a new job using that template
- Fails with exception below
OS: Ubuntu 18.04.6 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
* ShortCuts
* Help 1.0.3
Version: 0.21.30256 (Git) AppImage
Hash: 55866fd62221beadad3cfd60915278b156609a66
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
* ShortCuts
* Help 1.0.3
- Also fails to indicate which template value is bad
- Other cases not tested, it seems likely that other Op Default settings have the same problem.
- I noticed that other "int" values that are saved in the template as strings, and that they work on import (e.g. Tolerance).
Detailed Steps:
- Create a new freecad file
- Create a job with Stepover
- create a part-design body with a primitive box. We only need it as a dumy for the job.
- change to Path workbench
- select the body
- create a job
- set the OpDefaults:"Op Pocket Shape":StepOver to 90
- Close task with "ok"
- Save with some name like "import-crash-test"
- Export a job template with StepOver
- edit the job
- from the General tab, section "Template Export"
- make sure "Setup Sheet" is checked
- click export
- choose some name like "import-crash-test"
- should be saved in the Freecad Macros folder
- click the task "ok"
- Test job-creation with template
- select the body
- create a job, but choose the template saved above, e.g. "import-crash-test"
- job creation fails. Displays an exception in the Report View (show below). Does not indicate which template value is bad.
- Test job-creation with workaround
- Edit the .freecad/Macros/job_import-crash-test.json
- (or used the minimal job.json below which only has the StepOver value).
- Change to
"StepOver": "90"
. i.e. remove quotes.Code: Select all
"StepOver": 90
- succeeds with no error, opening a task gui.
- examine the OpDefaults:"Op Pocket Shape":StepOver, should be 90
10:53:39 PathJobGui.ERROR: {'sclassname': 'N4Base9TypeErrorE', 'sErrMsg': 'type must be int, not str', 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': 'type must be int, not str', 'btranslatable': False, 'breported': False}
10:53:39 Traceback (most recent call last):
10:53:39 File "/tmp/.mount_freecacZe8XQ/usr/Mod/Path/PathScripts/PathJobGui.py", line 1641, in Create
obj = PathJob.Create("Job", base, template)
10:53:39 File "/tmp/.mount_freecacZe8XQ/usr/Mod/Path/PathScripts/PathJob.py", line 866, in Create
obj.Proxy = ObjectJob(obj, models, templateFile)
10:53:39 File "/tmp/.mount_freecacZe8XQ/usr/Mod/Path/PathScripts/PathJob.py", line 241, in __init__
self.setFromTemplateFile(obj, templateFile)
10:53:39 File "/tmp/.mount_freecacZe8XQ/usr/Mod/Path/PathScripts/PathJob.py", line 596, in setFromTemplateFile
self.setupSheet.setFromTemplate(attrs[JobTemplate.SetupSheet])
10:53:39 File "/tmp/.mount_freecacZe8XQ/usr/Mod/Path/PathScripts/PathSetupSheet.py", line 290, in setFromTemplate
prop.setupProperty(
10:53:39 File "/tmp/.mount_freecacZe8XQ/usr/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py", line 71, in setupProperty
setattr(obj, name, value)
10:53:39 TypeError: {'sclassname': 'N4Base9TypeErrorE', 'sErrMsg': 'type must be int, not str', 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': 'type must be int, not str', 'btranslatable': False, 'breported': False}
10:53:39
line 2383, in create_job
obj = PathScripts.PathJob.Create('Job', model_list, template)
File "/tmp/.mount_freeca4Ub7TW/usr/Mod/Path/PathScripts/PathJob.py", line 866, in Create
File "/tmp/.mount_freeca4Ub7TW/usr/Mod/Path/PathScripts/PathJob.py", line 241, in __init__
File "/tmp/.mount_freeca4Ub7TW/usr/Mod/Path/PathScripts/PathJob.py", line 596, in setFromTemplateFile
File "/tmp/.mount_freeca4Ub7TW/usr/Mod/Path/PathScripts/PathSetupSheet.py", line 290, in setFromTemplate
prop.setupProperty(
File "/tmp/.mount_freeca4Ub7TW/usr/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py", line 71, in setupProperty
<class 'TypeError'>: {'sclassname': 'N4Base9TypeErrorE', 'sErrMsg': 'type must be int, not str', 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': 'type must be int, not str', 'btranslatable': False, 'breported': False}
10:39:35 PathJobGui.ERROR: {'sclassname': 'N4Base9TypeErrorE', 'sErrMsg': 'type must be int, not str', 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': 'type must be int, not str', 'btranslatable': False, 'breported': False}
10:39:35 Traceback (most recent call last):
10:39:35 File "/tmp/.mount_FreeCAbAsFIX/usr/Mod/Path/PathScripts/PathJobGui.py", line 1641, in Create
10:39:35 File "/tmp/.mount_FreeCAbAsFIX/usr/Mod/Path/PathScripts/PathJob.py", line 868, in Create
10:39:35 File "/tmp/.mount_FreeCAbAsFIX/usr/Mod/Path/PathScripts/PathJob.py", line 241, in __init__
10:39:35 File "/tmp/.mount_FreeCAbAsFIX/usr/Mod/Path/PathScripts/PathJob.py", line 596, in setFromTemplateFile
10:39:35 File "/tmp/.mount_FreeCAbAsFIX/usr/Mod/Path/PathScripts/PathSetupSheet.py", line 290, in setFromTemplate
prop.setupProperty(
10:39:35 File "/tmp/.mount_FreeCAbAsFIX/usr/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py", line 71, in setupProperty
10:39:35 TypeError: {'sclassname': 'N4Base9TypeErrorE', 'sErrMsg': 'type must be int, not str', 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': 'type must be int, not str', 'btranslatable': False, 'breported': False}
prop.setupProperty(
<Exception> ObjectIdentifier.cpp(1533): Document object 'SetupSheet' not found in 'SetupSheet.HorizRapid'
in property binding 'test_import_crash#TC__Default_Tool.HorizRapid'
"SetupSheet": {
"Pocket3D": {
"StepOver": "90"
"Version": 1
"90"
90
Full job template:
"Fixtures": [
"G54": true
"OrderOutputBy": "Operation",
"Post": "xopensbp",
"PostArgs": "--comments",
"SetupSheet": {
"ClearanceHeightExpression": "OpStockZMax+${SetupSheet}.ClearanceHeightOffset",
"ClearanceHeightOffset": "5.00 mm",
"FinalDepthExpression": "OpFinalDepth",
"HorizRapid": "9.87 mm/min",
"Pocket Shape": {
"CutMode": "Climb",
"OffsetPattern": "ZigZag",
"StepOver": "90",
"ZigZagAngle": "45.0"
"Pocket3D": {
"CutMode": "Conventional",
"StepOver": "90"
"SafeHeightExpression": "OpStockZMax+${SetupSheet}.SafeHeightOffset",
"SafeHeightOffset": "3.00 mm",
"StartDepthExpression": "OpStartDepth",
"StepDownExpression": "OpToolDiameter",
"VertRapid": "2.00 mm/min"
"SplitOutput": false,
"Stock": {
"create": "FromBase",
"version": 1,
"xneg": "3.17 mm",
"xpos": "3.17 mm",
"yneg": "3.17 mm",
"ypos": "3.17 mm",
"zneg": "0.0 mm",
"zpos": "1.0 mm"
"Tolerance": "0.01",
"ToolController": [
"dir": "Forward",
"hfeed": "111.76 mm/s",
"hrapid": "0.16449999999999998 mm/s",
"label": "1/4in Endmill015",
"name": "__4in_Endmill002007",
"nr": 2,
"speed": 16000.0,
"tool": {
"attribute": {},
"name": "1/4in Endmill047",
"parameter": {
"Chipload": "0.00 mm",
"CuttingEdgeHeight": "25.40 mm",
"Diameter": "6.35 mm",
"Flutes": "2",
"Length": "50.80 mm",
"Material": "HSS",
"ShankDiameter": "6.35 mm",
"SpindleDirection": "Forward"
"shape": "endmill.fcstd",
"version": 2
"version": 1,
"vfeed": "55.88 mm/s",
"vrapid": "0.03333333333333333 mm/s",
"xengine": [
"expr": "${SetupSheet}.HorizRapid",
"prop": "HorizRapid"
"expr": "HorizFeed / 2",
"prop": "VertFeed"
"expr": "${SetupSheet}.VertRapid",
"prop": "VertRapid"
"Version": 1
