exporting gcode in mmg file
GeneFC
Re: exporting gcode in mmg file
Post by GeneFC »
It seems most of those should be in the preamble. Just delete them from the postprocessor code.
The M and T codes are added by the Path WB. You may need to catch those and remove one by one.
I do not use those codes either, and here is an example of how I removed them.
  # Check for Tool Change:
            if command == 'M6':
                # if OUTPUT_COMMENTS:
                #     out += linenumber() + "(begin toolchange)\n"
                # for line in TOOL_CHANGE.splitlines(True):
                #     out += linenumber() + line
                outstring.pop(0)  # remove the command
                pass
I did not actually remove anything, but just added the comment symbol, #, to the front of the lines I did not want.
It should go without saying that you need a custom postprocessor that does not get changed when you install a new version of FreeCAD. That custom postprocessor can go in the macro folder in the same area as your configuration files.
Gene
