exporting gcode in mmg file
newtothis
Post by newtothis »
Is there any way to export a job as a .mmg file so it can be used on a laguna cnc router
any info is very much apriciated, thank you :D
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
  * LCInterlocking
Thanks for the time you so graciously spent to help me. :D
Re: exporting gcode in mmg file
We need more information about the code flavour of your machine. Have a look at the Path Postprocessor Customization page to see what it needs to better judge your postprocessor.
Mod edit: Moved to Path/CAM subforum
newtothis
Post by newtothis »
I have a postprocessor config file for vcarve which i downloaded from laguna's website but i don't know what to do to make a freecad post processor from it
The vcarve post processor config file is in the attached zip file
Swift (1).zip
(1.88 KiB) Downloaded 39 times
GeneFC
Post by GeneFC »
newtothis wrote: Fri Sep 09, 2022 12:59 am I don't know what to do to make a freecad post processor
I have no knowledge of either V-Carve or Laguna, but when looking at the config file you attached it appears that the g-code is a basic subset of world-wide standard g-code. A typical post-processor such as LinuxCNC or Grbl might work.
The real issue will be determining what pre-headers or post-commands are needed. I do not know of any method to determine those items without reference to documentation from Laguna.
Does Laguna specify what inputs are required?
The extension (.mmg) is irrelevant for FreeCAD. The output will be the same regardless of the extension. If you want to try the output from Linuxcnc or Grbl or whatever, just change the output file extension to mmg. In all cases the g-code is just a simple text file.
Gene
I have linked a wiki page above. Can you post here a working gcode file for the tombstone from that page?
jbraun
Post by jbraun »
Curiosity lead me to AutoDesk
https://forums.autodesk.com/t5/hsm-post ... -p/6081140
which shows the top of a file supposedly direct from Laguna tech support
N0S18000M03
N10X0.000Y0.000F11430.0
N20G00X84.846Y101.282Z17.780
N30G1Z-0.254F762.0
N40G1X140.237F11430.0
N50G3X145.000Y106.045I0.000J4.763
N60G1Y155.282
N70G3X140.237Y160.044I-4.762J0.000
N80G1X84.846
N90G3X80.083Y155.282I0.000J-4.762
N100G1Y106.045
(more stuff)
N2420G00Z17.780
N2430M05
N2440M30
So it may not understand planes (G17) or fixture offsets(G54) or switching units (G20/G21). Or it does and they skipped the preamble (dangerous).
Line 10 is strange in having a feed with no explicit G1. Other than that it looks pretty generic.
Laguna won't have a FreeCad post but they should be able to provide a manual for this control.
GeneFC
Post by GeneFC »
chrisb wrote: Fri Sep 09, 2022 5:16 am I have linked a wiki page above.
Wrong topic?
GeneFC wrote: Fri Sep 09, 2022 2:32 pm Wrong topic?
I hope not. I had linked the Path Postprocessor Customization page, and it would be interesting to see the G-code for this tombstone:
A file milling this would have header and footer and would show how a straight line is coded and an arc with a non zero center.
GeneFC
Post by GeneFC »
chrisb wrote: Sun Sep 11, 2022 6:54 pm I hope not.
Sorry. This link was not visible to me until I hovered over it. :oops:
Gene
