[solved]Path post-processor and GRBL
dddns
Post by dddns »
Hello :)
For me, the post processor for GRBL does not work correctly.
If I drill holes, the gcode contains G83 drilling cycle and G99 commands, which GRBL does not understand and will lead to an error.
Does somebody experiences same problems?
GeneFC
Re: Path post-processor and GRBL
Post by GeneFC »
dddns wrote: Mon Aug 08, 2022 3:27 pm
If you select "peck" in the drilling task panel you will get G83. If you do not select special operations, peck or dwell, then the code should contain only G81.
Gene
dddns
Post by dddns »
Thanks for your answer Gene.
GRBL does not support any of the cycle gcode commands.
The only solution would be, if the post-processor would translate retraction and all other moves to G0/G1 linear moves.
LarryWoestman
Post by LarryWoestman »
Looking at the source code, it appears that the GRBL post defaults to not translating G81, G82, and G83 commands. If you want it to translate, you need to use the "--translate_drill" option.
This seems to depend on the grbl capabilities of your mill. You can try playing with the --no-translate-drill option.
spanner888
Post by spanner888 »
The grbl post processor has a default option:
--no-translate_drill    "don't translate drill cycles G81, G82 & G83 in G0/G1 movements (default)"
So try adding to the Job - output the option:
--translate_drill
There are other posts in the forum explaining in more detail, just search for "translate_drill"
dddns
Post by dddns »
Using "--translate_drill" was the solution.
Many thanks to you all!
Re: [solved]Path post-processor and GRBL
Sorry if I caused confusion with the inversed option.
boothdcb
Post by boothdcb »
dddns wrote: Tue Aug 09, 2022 7:05 am Using "--translate_drill" was the solution.
This seems to be a common problem for home build CNC mill projects that use grbl. So how do I change the default option to "--translate_drill". I could do with a simple guide. It might be helpful if, in future developments of the Path workbench, there was an option to do this when grbl is selected as the post processor.
mlampert
Post by mlampert »
boothdcb wrote: Thu Sep 29, 2022 2:46 pm This seems to be a common problem for home build CNC mill projects that use grbl. So how do I change the default option to "--translate_drill". I could do with a simple guide. It might be helpful if, in future developments of the Path workbench, there was an option to do this when grbl is selected as the post processor.
You should find everything you're looking for in the Path Preferences.
