Weird Path behavior - SOLVED!!
dkolars
Post by dkolars »
Drew shape (toothed gear)... added squares inside. Went to Path, created a Job, selected all the faces of the squares inside the main shape. Set all the cutting depths/speeds/etc. Clicked "OK". Got this!!
What the what? I have had this happen before, and can see nothing wrong in what I've done. Clicking any of the Model-Body.Faces in the Base Geometry of the Profile highlights the faces inside the squares. Yet, the program is drawing the cut on the inside of the outer face!! That will be the last cut, and on the OUTSIDE of the outer face!
Any idea why this behavior happens, and what might cause it?
Just go the newest AppImage yesterday, and had no problems then, and like I said, this has happened before.
TIA
Gear - Clock - Squares.FCStd
(148.4 KiB) Downloaded 30 times
OS: Ubuntu 20.04.3 LTS (XFCE/xubuntu)
64-bit
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
dkolars
Re: Weird Path behavior
Post by dkolars »
SOLVED!!
I deleted all the faces, tried again. Nope... so went ahead and did the outside to see if it would work... yes, it did, but did not cut the shape of the teeth, cut a curve in, then back out. Hmmm
AHA... turned off "Use Compensation" and added half the bit dia to the "Extra Offset" box, and 'poof', all is working. I was under the impression that the Compensation was doing that offset, but apparently not... time to do some reading...
64-bit
Qt version: 5.12.9
dkolars wrote: Fri Jan 14, 2022 3:00 amI was under the impression that the Compensation was doing that offset, but apparently not...
Yes it should. Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
Re: Weird Path behavior - SOLVED!!
In the file from the original post you have to switch in Profile/Operation the Cut Side from Inside to Outside.
OS: macOS 10.16
Version: 0.20.27008 (Git)
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
dkolars
Post by dkolars »
chrisb wrote: Fri Jan 14, 2022 6:47 am
Branch: (HEAD detached at 0.19.2)
Qt version: 5.12.9
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
chrisb wrote: Fri Jan 14, 2022 6:51 am In the file from the original post you have to switch in Profile/Operation the Cut Side from Inside to Outside.
In the original post, I had NOT selected the outer faces of the drawing, but the 40 faces of the squares on the inside, set to Cut Side on the inside. FC created a path to cut the INSIDE of the outer faces, NOT what I had selected!! Hence my post.
Here is the finished file
(156.03 KiB) Downloaded 30 times
64-bit
Qt version: 5.12.9
Moved to Path subforum
GeneFC
Post by GeneFC »
dkolars wrote: Fri Jan 14, 2022 11:15 pm In the original post, I had NOT selected the outer faces of the drawing, but the 40 faces of the squares on the inside, set to Cut Side on the inside. FC created a path to cut the INSIDE of the outer faces, NOT what I had selected!! Hence my post.
I looked at the original file, and there was a significant problem.
The entire top face was selected (Face83) in addition to the many faces for the holes. That is why the entire shape was processed.
When I tried, without your tool set, the default tool was too large to fit inside the holes. You may have had a small tool selected that did not come through in the posted file, however.
Gene
or probably, as the toolpath seems to show, tool diameter is too big to cut out holes.
