3D pocket anomaly
3D pocket anomaly
I just made 3d pocket path and it looks as expected, except for one line which plunges through the base of the model a clears a small rectangle.
The anomalous line can be seen lower right in the screenshot.
Is there some anomaly in my 3D model which is causing this, it looks fine to me ?
Thanks.
OS: Fedora 34 (Thirty Four) (LXQt//usr/share/xsessions/lxqt)
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.15.2
OCC version: 7.5.0
Thanks.
Qt version: 5.15.2
OCC version: 7.5.0
- 3Dpocket-anomaly.png (5.19 KiB) Viewed 2878 times
- 3Dpocket-anomaly.FCStd
- (132.25 KiB) Downloaded 29 times
Re: 3D pocket anomaly
Preliminary remarks not directly related to your issue:
It is always appreciated if you upload simplified models which show exactly the issue and nothing else. That's much less time for the helpers than just throwing a complete model over the fence.
Furthermore you should work on your sketching. Placing the whole model centered around the origin would have made things much easier. And probably better. I guess that in sketch under-cut-profile-Sketch the center of the arc should be on the symmetry line as well. Alas, it is more than a mm off, as the driven dimension at the top shows: I'm still working on the issue, at least to simplify the model, so that the experts can help.
Here is a simplified model still showing the same issue.
Edit: replaced by something even simpler
- 3Dpocket-simplified_cb.FCStd
- (32.82 KiB) Downloaded 31 times
Thanks for taking a look Chis.
I had not noticed that line was off. Good catch. Earlier I had the symmetry constraint on the ends of the arc and this was leading to an inaccuracy. When I removed the sym that vertical line went off to one side and I had to apply a vertical constraint. I think that must have shifted something off screen which I did not notice. I was a bit surprised it went off vertical because even if the implicit vertical of sym was removed, it should have stayed were it was.
I did not bother stripping it down because my initial expectation was I may be doing something wrong.
Anyway, it does seem like there is an issue there. It seems that small uninteded offset is triggering a bug in the pocket algorithm.
Thanks for the stripped down example.
BTW, the reason this is not centred on y axis is because I am replicating an existing part. The defining feature is the outer rectangle, so that is where I put the axes. There is no physical centre line on the part so nothing is measured relative to that. The order of construction was based on pinning down dimensions until I had it replicated.
Just for reference, here is the earlier version of the file before I moved the symmetry constraint. Here the arc centre was still on the centre line and it does not produce the buggy 3Dpocket path.
- 3DpocketOK.FCStd
- (183.42 KiB) Downloaded 31 times
I will have another look later, but would be happy if someone knowing better can jump in.
Thanks Chris, it's not a current problem for me since I've corrected the model and used 3Dsurface instead.
However, this particular geometry clearly has exposed a bug which ought to be looked at.
I replaced the file in the post above by something even simpler. It contains only a single pad, but shows the same defect:
- SnipScreenshot-48feae.png (14.65 KiB) Viewed 2542 times
Nice work, stripped down to the essentials and a bit more asymmetry to make it clearer what is happening. That breakthrough plane is more than a glitch now. That should help a lot.
One advantage is, that it is clearer now that the model doesn't have any hidden defects.
