pick pocket problem.
freman
Post by freman »
I have a 3D part with two pockets in a block. When I try to get a pocket path it fails. It seems it is impossible to select the just the bottom of one pocket in 3Dveiw. Which ever I click on I get both selected.
In the path edit I just see one face selected but it fails creating a path:
13:59:29  PathFeatureExtensions.ERROR: Extend Outline error 2
13:59:29  PathFeatureExtensions.ERROR: Waterline error 1
13:59:43  PathPocketShape.ERROR: Pocket does not support shape Model-Body.Face70
13:59:43  PathGeom.INFO: Zero working area to process. Check your selection and settings.
Originally this piece had a slot between the two pockets on the reverse side. Which I set to zero depth. The screenshot seems to show three difference surfaces getting highlit when I click on either of the curved inner surfaces.
First screenshot is taken from the top of the pocket in the path dialogue.
It seems odd I can select separate faces in the path dlg but not in 3D view. Is there some ambiguity in the model which is confusing the 2.5D pocket tool?
I was expecting the 2.5D tool to project the area on z=0 plane and clear the main volume, then I can use 3D tool to dig out the concave bottom surface.
TIA.
[EDIT]
New pocket-error-tidy.FCStd file. I've tidied up some very slight misalignments in the model due to where I was placing symmetry constraints but this does not seem to fix the issue.
OS: Fedora 34 (Thirty Four) (LXQt//usr/share/xsessions/lxqt)
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.15.2
OCC version: 7.5.0
(147.42 KiB) Downloaded 22 times
pocket-error.FCStd
(161.09 KiB) Downloaded 18 times
