How to deburr selected edges only?
Hi to all,
what if I need to deburr only specific edges of my object?
The deburr operation seems to work if
- I select exactly one edge;
- I select a closed path.
However, if I select a sequence of edges and then I click on the deburr-op, the command doesn't work.
For example, I tried to select two edges of a simple cube, but the command fails:
Any clue?
Any clue?
- deleteme-deburr-test.FCStd
- (16.4 KiB) Downloaded 28 times
Re: How to deburr selected edges only?
Did you use the latest 0.20?
Yes. One of the latest build.
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.20.26375 (Git) AppImage
Branch: (HEAD detached at 8a6e3d1)
Hash: 8a6e3d1b766a34546806b22d750929c2d00e30a6
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
Use a BoundaryDressup:
- deburrTwo.FCStd
- (12.53 KiB) Downloaded 27 times
- SnipScreenshot-5423f3.png (12.11 KiB) Viewed 2248 times
Uh!
That is a real PITA when the path has multiple "interruptions"... one has to create multiple bounding-boxes... Also my object is rotated around the Z-axis and I have to search for exact coords over any edge to be avoided.
Another approach to deburring:
there is no way to "draw" your own arbitrary path around a solid by using 2D geometries? (Even if some manual refinement of the gcode would be necessary later?)
This is my experience also.Giulio Buccini wrote: ↑Fri Nov 26, 2021 1:27 pm Hi to all,
Any clue?
But an odd thing is this only seems to be a problem when the adjacent edges are straight edges (lines).
If I select a chain of edges that have straight edges connected to arcs there is not a problem until I introduce two consecutive straight edges (lines).
I need to read the Thread for Deburr (original creation thread) from the beginning to get a better idea of the operation as there seem to be a few odd things going on.
I have to test this strange behaviour...
Anyway, it is quite strange that, despite offering amazing features, Freecad does not offers the simplest ones.
In case it helps finding th cause of this behaviour: engraving works well on a set of single edges.
Hi ,
Further to the apparent issue I tried an extremely small and unrealistic fillet between two adjoining edges to check if the de-burr failure might be a precision issue.
A 0.001mm fillet will actually process correctly, but a square edge will not.
( I could only select the fillet with "Finish Selecting Loop" and the deleting edges not joined by a radius.)
In the attached file the path with the fillet produces a correct result.
The path with square edge fails catastrophically, it processes the inside of the two edges and then the outside of the second one.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.26479 (Git) AppImage
Branch: (HEAD detached at 00e0fc7)
Hash: 00e0fc73d950a26d9cc41bbc861a53bda7754d58
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
- Deburr_bug.FCStd
- (18.18 KiB) Downloaded 20 times
I was thinking about that. But I have to calculate an outline, i.e. a distance from the edges to be deburred.
How I could achieve that?
I was thinking to get a 2D-outline of my object by using the Draft-WB.
Here the supposed workflow:
1. switch to DraftWB
2. set top view
3. select the object and then apply "Shape 2D view"
4. transform the shape to a sketch by using "Draft to Sketch"
5. edit the sketch and erase all internal segments, so that only the outline remains
6. transform back the sketch to a 2D shape
7. produce an offset outline of the obtained shape, so that the offset is equal to the asked/required distance of the Chamfer/V-bit tool from the edges
8. Switch to the Path workbench and use the offset-ted 2D-shape as path for an engrave operation
10. Eventually change/adjust the height of the 2D-shape on the Z-axis to get a proper deburr.
Sounds reasonable?
How I get an offset from the 2D-shape at point 7 ???
