Can't select a body that's in an "assembly 4 part" for path operations
Lupin
Post by Lupin »
When I put "Part Design WB" bodies (or "Part WB" primitives) into an "Assembly 4" "Part", I am no longer able to choose that body as part of the "Model" for a "Path" Job.
For example with this simple structure:
This is what I get when trying to create a new job:
The body is not available for selection.
Similarly, and somewhat related I guess, I can't select and add the sketch within the body to a job either (for engraving for example). This is independent of the body being within a "Part". If I make "Draft" clones of the body or sketch to document root, I can add them to a job. What's even weirder and makes me think the behaviour is a bug: after I added the clones to the Job, I can select them in the tree and change their "Objects" property to the original body or sketch, which are still within the "Part" (or within the body for the sketch resp.) and everything (profiling, pocketing, engraving,...) works fine. The clones aren't even needed anymore. The only problem: doing any edit to the "Job" object itself (via the dialog, not the properties) will most likely break something.
That the bodies and sketches can be used after that workaround, but can't be selected via the job dialog, seems like a bug to me.
Version: 0.20.Unknown
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: German/Austria (de_AT)
path_unable_to_select_sketch_or_body_worked_around.FCStd
(27.8 KiB) Downloaded 13 times
path_unable_to_select_sketch_or_body.FCStd
(12.97 KiB) Downloaded 13 times
MRx
Re: Can't select a body that's in an "assembly 4 part" for path operations
Post by MRx »
Just to add it here, Inventor imports don't work with the Path Module either. IGES however works (but caused other delicate issues on my side).
There's still a bit work to do at the Path entry scripts.
