I want to create circular paths in XZ and YZ planes. So I made custom paths using G18 and G19 commands.
But when I do the simulation I get wrong results. It seems that the operations are always made in the XY plane.
Does anyone know if it is a real problem for the milling or just a display problem from FreeCAD ?
Problem with G18 and G19 commands in path wb
- XZ_YZ_result.png (28.62 KiB) Viewed 862 times
- XZ_YZ_plane.png (34.21 KiB) Viewed 862 times
- testGCode_g2.FCStd
- (46.65 KiB) Downloaded 18 times
Re: Problem with G18 and G19 commands in path wb
Hi and welcome to the forum!
Moved to Path forum.
I am pretty sure that the simulator works only on XY - as do most Path commands.
