Freecad version: 0.20 (daily)2021/11/13 10:22:00 (I do not update so often)
Downloaded marlin_post.py (2021/11/17) from:
https://raw.githubusercontent.com/FreeC ... in_post.py
I checked the marlin_post.py file and saw:
# * Initial configuration, not changeable
UNIT_FEED_FORMAT = 'mm/s'
updated it inside the py-script
UNIT_FEED_FORMAT = 'mm/min'
-> Now it works fine... I will try to experiment with the grbl and marlin version, if they are similar "stable"
Below message only for completeness (This happened, before I updated marlin_post.py),
Inspect G-Code shows:
G1 F10.000000 X99.966543 Y-10.995009 Z1.500000
Path Postprocess shows (same is in the generated gcode file):
G1 X99.967 Y-10.995 Z1.500 F10.000
Tool shows Vert Feed = 600mm/min
In operations data fields I cannot find any feedrate (Btw: I would not expect the values there)
Freecad started today evening, configuration checked
