Trouble installing Path Post Processor
I downloaded "snapmaker_freecad_post.py" and installed it to the "C:\Program Files\FreeCAD 0.18\Mod\Path\PathScripts" folder. I then started FreeCAD. The post processor still does not show up in the list when I set up a new job.
What else do I need to do?
Thanks
Thanks
Re: Trouble installing Path Post Processor
Hi and welcome to the forum!
Wrong directory. A working but still inferior solution would be to place it in the "post" subdirectory. If you upgrade your post processor would be lost.
A better solution is to place it in your personal FreeCAD macro directory.
The best solution is to additionally provide it to the FreeCAD community.
Thanks for the response. I still haven't been able to get it to work. I copied the .py file to c:\\user\AppData\Roaming\FreeCAD\Macro. Are there any other installation steps required?
The link to the post processor is:
https://github.com/Snapmaker/snapmaker_cnc_post_process
It would be nice if it was added to the distribution program.
Thanks again
Thanks again
I have no idea what a snapmaker is, but I downloaded the post processor, added it to my macro folder, and it showed up in FreeCAD just as described above.
The folder you show is not quite correct. It should be C:\\Users\#####\ AppData\Roaming\FreeCAD\Macro, where ##### is your Windows user ID.
If you copied the file exactly as you show, then that is the problem.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24219 (Git)
Hash: 8c26baebab320b8c1c3279bc8eb34a1eb6c7a363
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Gene
I struggled with the same issue while trying to install a new post. I did get it to work properly by placing the '_post.py' file in the:
directory as suggested by @chrisb. I needed to create the directory as it wasn't there by default.
The FreeCAD Wiki may need to be updated to reflect this though. The documentation indicates that the '_post.py' files are saved in the:
location by default. This directory, at least on Manjaro and EndeavorOS, did not exist by default. I'm not sure where FreeCAD is pulling the current list of included post processors from. If I create the location and move the '_post.py' files there, FreeCAD is unable to find them. The same is true if the folder is created in the user's $HOME/.FreeCAD directory. While attempting this to see if it'd work, it broke the Path workbench in FreeCAD completely for me.
Cheers!
OS: Manjaro 64-Bit & EndeavorOS 64-Bit
FreeCAD Version: 0.19.24219 (Git)
Build Type: Release
Python version: 3.9.7
Qt Version: 5.15.2
DE: LeftWM
$HOME/.FreeCAD/Macro
/usr/share/freecad/Mod/Path/PathScripts/Post
Cheers!
Build Type: Release
Qt Version: 5.15.2
DE: LeftWM
if ($hungry) { eat(); } else { sleep(); }
SaazyPants wrote: ↑Sun Nov 28, 2021 7:01 pm I struggled with the same issue while trying to install a new post. I did get it to work properly by placing the '_post.py' file in the:Code: Select all
Maybe they are not installing FreeCAD in this way, some distribution tend to move around and "override" standard path, maybe putting something under /opt/ or /usr/local/ instead of /usr/.
For similar things you have not to blame distributions packagers, that change "--installdir"
Documentation is usually referring to the "standard location" of a file, if distribution packagers will modify this location, obviously the path is not the same you will find in documentation.
Please give a link to the wiki. Makes it easier if we want to change the text to something more generic.SaazyPants wrote: ↑Sun Nov 28, 2021 7:01 pm The FreeCAD Wiki may need to be updated to reflect this though. The documentation indicates that the '_post.py' files are saved in the:
The thought didn't cross my mind until a week later that it might be related to Manjaro / Endeavor choosing a non-standard install location. Your post reminded me to just run "whereis freecad" on both systems and see where they tossed it... apparently both distributions place the post files in:Maybe they are not installing FreeCAD in this way, some distribution tend to move around and "override" standard path, maybe putting something under /opt/ or /usr/local/ instead of /usr/.
/usr/lib/freecad/Mod/Path/PathScripts/post
@chrisb - Here's the specific section of the wiki just in case additional clarity or information should be deemed needed. The standard path is described under Other Post Processors (https://wiki.freecadweb.org/Path_Postpr ... tomization)
Thanks for the feedback!
Cheers,
Saazy
Recently I've been using the Flatpak version of FreeCAD. Finding the location to place the post.py file was kind of a chore as I'm not terribly familiar with Flatpaks overall. I figured someone else may struggle with this and wanted to add to this post the file path that worked for me on Arch-Based distros (Endeavor / Manjaro).
/var/lib/flatpak/app/org.freecadweb.FreeCAD/current/active/files/freecad/Mod/Path/PathScripts/post/
