Path Pocket Shape: 4th-axis Integration
Russ4262
Re: Path Pocket Shape: 4th-axis Integration
Post by Russ4262 »
cox wrote: Wed Apr 24, 2019 6:45 pm ...For the time being it feels like, all I have time to play with is diapers :-)
One just potty trained and working on the second...
Thanks!
Russ
RatonLaveur
Post by RatonLaveur »
Hello gents,
Russ, I've been trying out the new options and they fit just right.
The B-axis override is fantastic to visualize the correct path in FreeCAD...of course, it means that the actual NC code viewed with NCviewer is all scrambled :)
I'll play around with the B and A axis selections. Thanks a lot!
As soon as i'm comfortable enough with this, I'll definitely machine something and show :)
EdgeChannels.FCStd
(184.56 KiB) Downloaded 93 times
Russ4262
Post by Russ4262 »
Good evening, Mates.
RatonLaveur wrote: Fri Apr 26, 2019 2:41 pm The B-axis override is fantastic to visualize the correct path in FreeCAD...of course, it means that the actual NC code viewed with NCviewer is all scrambled :)
REMEMBER: Toggle all "B_Axis Error Override" properties to FALSE before exporting gcode for your machine.
This will leave B(y) axis rotations to appear incorrect in FreeCAD, but should be fine in the real world and NCViewer and Camotics.
RatonLaveur wrote: Fri Apr 26, 2019 2:41 pm I'll play around with the B and A axis selections. Thanks a lot!
This "Use Rotation" property will need some adjustments within the code. I don't think it functions quite as smoothly as we would like. It does, nonetheless, provide the intended result within my limited testing.
Wsk8 wrote: Wed Apr 24, 2019 4:36 pm... all ops are usually based on the model :)
I have updated the scripts attached to the initial post of this topic. Version 1f_testing should respect XYZ linear translations done within Job setup. Also, a property to select the rotational axis is available.
Thanks for the feedback gentlemen! Proceed with caution and the correct feeds and speeds... :)
Cheers,
Russell
mlampert
Post by mlampert »
I finally had some time to look at your changes and I might be doing something wrong (I usually do). Attached file results in the following Path:
The pocket is in the positive Z direction and doesn't need any rotation. There's also something funny with the depths happening. Regardless of what I set the "FinalDepth" to it gets reset to being -10 during the recompute. And although "StartDepth" is at +22 the actual path starts at -22.
This is great stuff - I love it!
4th-axis.FCStd
(56.95 KiB) Downloaded 95 times
Russ4262
Post by Russ4262 »
Afternoon, MLampert.
mlampert wrote: Sun Apr 28, 2019 10:21 pm I finally had some time to look at your changes and I might be doing something wrong (I usually do)...
Please don't be upset. I opened the file, toggled the "Reverse Direction" property, and recomputed. Wha-lah.
This is an issue perhaps your expertise or @Sliptonic, or @JoshM, or another one of the many FC contributors could help me solve.
I don't know if FreeCAD, NO, if I have the know how to tell FreeCAD how to identify the direction of any pocket toward the exterior of the Model. From looking at your model, and based on usage of FreeCAD, and developing this script modification, I bet that your pocket in question was made by setting a cube, right-side-up, atop the body and doing a cut operation. This would leave the bottom face of that cube as the bottom of the pocket. This is the result of the script's analysis of that face using face.Surface.Axis: value is probably -Z or (0,0,-1). Therefore, the script thinks the direction of the pocket should be down, -Z.
I haven't taken time to figure out the algorithm needed to correctly orient any pocket's direction toward the outside of the Model. So... I have the "Reverse Direction" property for just these cases. At this, point, I think allowing the user to simply "Reverse Direction" of the pocket seems the easiest solution, and less difficult to code. If I find time, I may look into such an algorithm improvement. It would be great for certain!
mlampert wrote: Sun Apr 28, 2019 10:21 pmThis is great stuff - I love it!
+1 !
Let the chips fly, amigo.
Russell
Solution: toggle the "Reverse Direction" property.
Russ4262
Post by Russ4262 »
Morning FC Users,
I just posted updated versions of the two scripts involved in the Path Pocket Shape 4th-axis integration; they are available with the initial post of this topic. Some errors have been corrected:
  • Fixed broken PathWB operations related to PathAreaOp.py script: Tuple size differences in return values from Profile Faces, Mill Faces, and other tools based on PathAreaOp.py script are fixed. The affected tools seem to be back in action.
  • Depth parameter issue reported by @Sliptonic has been addressed. Tests results are correct, so far.
  • You might need to delete and recreate any Path Pocket Shape operations you have, after you install these scripts.
Thank you for testing and reporting errors.
More good news: @Mlampert and I agree we have found the missing negative sign to make the B-axis rotations render correctly in FC. Well, @Mlampert probably knew all along, where as I had to fumble around and backtrack code with python sniffing dogs trained from birth. But, that is beside the point. Initial testing after compiling the corrected code yields positive results. Thanks, @MLampert for all your coding contributions and other help! Once we get the correction committed to the master branch, the 4th-axis scripts we have been testing can be edited to remove the "B-axis render override" flag. Hallelujah!
Later,
Russell
RatonLaveur
Gentlemen,
I was rubbing my hands with the added file, hoping to check for capabilities and interesting behaviors.
To my surprise, the 3D pocket is now behaving as if Russ had not performed his magic over last few weeks.
I'm using both of the most up-to-date files in the original post of this thread (rev. i usable)
Is there something I'm missing?
OS: Windows 7
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
Locale: French/Switzerland (fr_CH)
MultiHolePolar.FCStd
(65.25 KiB) Downloaded 84 times
Russ4262
Post by Russ4262 »
Evening RatonLaveur,
I opened your file. I see the problem - one of them.
RatonLaveur wrote: Thu May 16, 2019 11:31 am Is there something I'm missing?
It looks like you used the 3D Pocket tool originally. It does not support 4th-axis, yet. You need to use the Path Pocket Shape tool - circled in the attached image.
28 May 2019: Moved usage instructions to initial post in topic.
Submitting this model for assistance here in the forum has also exposed another error in the existing code. Pocket_Shape 4 is missing, as seen in the image. The operation is present, but no path is made. This is an error in the face analysis algorithm in the code; this pocket is mistakenly identified with the following error>> PathPocketShape.ERROR: Pocket does not support shape Model-Body001.Face3. I will take a look at it and work to correct the problem. I do not know if it is related to the use of the polar array or some other analysis issue.
Thanks!
Russell
MultiHolePolar (1).FCStd
(70.82 KiB) Downloaded 83 times
RatonLaveur
Hello Russ,
Thanks a lot. I don't know how I have become inept at using it after playing with it for the last few weeks. Thanks for the help.
Yes the model i made to really push the boundaries of what the 4th axis can do. It's parametric, you'll notice. That the holes are initially cardinal (aligned with X and Y) but all you have to do to make this into a nightmare is to add a few repetition on the polar pattern :) then it's compound angle...oh boy.
Cheers.
J.
RatonLaveur
Hello gents,
A little bit more feedback. Finally confident that I could use the 4th axis integration for actual testing in my 3+2 machine, I prepare a comparatively simple model: a square tip to be cut from square rod.
Fooling around with the options, the use of the Path Pocket shapes moves the model relative to the stock in a funny way. I see no reason why path pocket should move the work piece model that way.
To repeat the issue:
1. open Job setup
2. orient the tip to either X or Y axis (Z is now transversal to the feature main-axis.
3. select one of the faces of the tip, and select the pocket based on face
4. press apply (with intention of activating rotation of the A(x) and B(y) axis in the data tab afterwards.
What happens: the model moves relative the stock back to a main Z orientation.
Results are scrambled.
Strange strange.
Attached: pictures of what happens.
Attached: model to play with.
TipCutting.FCStd
(26.37 KiB) Downloaded 86 times
