Thanks.
(Please don't quote complete posts. It makes topics unnecessary long and obscures what your actually referencing.)
Tool Editor / Tool Table
Re: Tool Editor / Tool Table
- dubstar-04
Depends which machine I'm using. This one:
Version: 0.19.19635 (Git)
Hash: 757cfce10b87ca087d31ce38eb30f612bf55fcad
Python version: 3.6.8
Qt version: 5.12.1
I've opened a bug report and assigned it to me as this is likely my fault:
issue #4282
- dubstar-04
It seems that I am not able to create any new tools. When I open the Create Tool dialog, Path > Create Tool and edit the parameters and click OK, I get the following output in Report View -
Something broken, or is it just me?
Oh, and when one creates a new tool, where is it saved, or is it? There is no Wiki on the new tool manager and I'm at a bit of a loss as to exactly how it is suppose to work. My best guess at this point is that one makes new tools with the Path > Create Tool, and then it gets magically saved somewhere, where then it can be browsed to from the Tool Manager > Add Toolbit button and added to the Tool Library. Though at the moment I have no clue as to what extension the saved(??) Tools are under or where to go to find them in order to add them to the library, that is, once the clicking of the OK button in the Add Tool dialog stops producing the error.
Mark
OS: Ubuntu 18.04.4 LTS (KDE/plasma)
Version: 0.19.
Branch: unknown
Hash: 3ad15343ebab78cd76b7e9a06a0f8d794f5075be
Python version: 3.6.9
Qt version: 5.9.5
in _removebitbody
in _removebitbody
propname: ChipLoad
propname: Flutes
propname: LengthOffset
propname: Material
propname: UserAttributes
in _removebitbody
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathToolBitGui.py", line 142, in accept
self.editor.accept()
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathToolBitEdit.py", line 162, in accept
enabled = self.model.item(i, 0).checkState() == QtCore.Qt.Checked
<class 'AttributeError'>: 'NoneType' object has no attribute 'checkState'
Mark
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
This post made with 0.0% Micro$oft products - GOT LINUX?
- sliptonic
Hi Mark,
Likely something is broken. It's been getting some attention in the last couple weeks.
The best documentation at the moment is the readme https://github.com/FreeCAD/FreeCAD/tree ... Path/ToolsOh, and when one creates a new tool, where is it saved, or is it? There is no Wiki on the new tool manager and I'm at a bit of a loss as to exactly how it is suppose to work. My best guess at this point is that one makes new tools with the Path > Create Tool, and then it gets magically saved somewhere, where then it can be browsed to from the Tool Manager > Add Toolbit button and added to the Tool Library. Though at the moment I have no clue as to what extension the saved(??) Tools are under or where to go to find them in order to add them to the library, that is, once the clicking of the OK button in the Add Tool dialog stops producing the error.
Technically this is still an experimental feature so it should only be visible if you have those enabled. What's more, if you have enabled experimental features, BOTH systems are active unless you disable legacy tools in the preferences.
There's still too many items in the menu and some of those will go away as we refine the UI.
Even with all those caveats, I encourage you to use the new toolbits. It's the future.
You can save your toolbits and libraries anywhere you want. Toolbits and libraries are just json files with custom extensions (.fctb and .fctl) Libraries are very simple. Just lists of toolbits with a tool number assigned.
When you do Path -> Create tool, it only creates in memory. You have to manually save it (Path -> Save Tool) if you want to persist it. This is one of those things we will be improving.
Hi CNC people,
I just wanted to point out a couple of sites that build and export tool assemblies with the ISO 13399 standard. Maybe some of you know them already.
https://www.machiningcloud.com/app/
Here is a Capto turning tool exported to the GTC format.
http://www.filedropper.com/tool1
Another good tooling resource is Tools United.
https://www.toolsunited.com/App/
Wish I was more helpful in the coding department
Great work thus far Dan and all whom contribute!
At least the old style tooltable is stored in the user.cfg.
Thanks sliptonic, at least for now I pretty much know now it isn't me. Have some more questions coming. thanks in advance
Mark
Mark
