That is great, thanks in advance!
OpenCAMlib for Windows
Re: OpenCAMlib for Windows
There are some minor issues which I will fix in the next days.
LMH,
Thanks for contacting us on the forum. I have taken a look at your image posted, downloaded the referenced file and played with the operation and tool settings until my results resembled yours in the image.
Otherwise, I can say that the paths are correct on the left side of the model (using my attached image for reference). Based upon what I see in your image and mine, you have a ball nose (rounded end mill) tool selected for the operation - about a 6.35mm diameter cutter. You can see in the attached picture on the left, the cutter drops in Z height to accommodate the ball nose curvature of the cutter - to fit the corner of the model.
I do however see we need to adjust the path calculations on the right side(terminal side) of the model. If the tool were a standard end mill (as in the last picture), the current path would be correct. However, it needs to be adjusted for the ball nose cutter. Other cutter types would more than likely need the same adjustment on that right side when finishing the model. The paths on the right should mirror those on the left in this situation.
Again, thanks for the feedback, Sir. I will work on the solution as time permits. I am limited on time for the next few days, but will have more time in the next few weeks.
I'll have to attach the model file I used for the screen shots later. Network restrictions on this machine hinder uploading the file to third-party site and giving you a link. I'll do that when I have access to my normal work station, and update this post accordingly.
Update: 2019-05-14 Model file link
mfg
Russell
First, for future reference, if at all possible, please attach a copy of the exact FreeCAD model file to which you are referring in the post. Having the exact file in the state in which the condition occurs provides the developers with a lot more information. Also, please include the tool information if possible - type, diameter, etc..
mfg
Russell
- Surface_0_A-1.png (202.5 KiB) Viewed 2728 times
- Surface_0_A-2.png (198.25 KiB) Viewed 2728 times
- Surface_0_A-3.png (205.74 KiB) Viewed 2728 times
Good afternoon, LMH.
I had a moment to look into the path issue you identified. I have adjusted the scan algorithm. I am attaching the modified script. I think you will find it more to your liking - at least on the model we are discussing.
I do appreciate the feedback!
mfg
Russell
I will update the attached script at 3D Surface: 4th-axis Integration and more... to this updated version. Feel free to download from there and try it out. You will probably have to delete and re-create your surface op after installing the new script. It has a new property added to it for limiting the cutter boundary (until I can edit the actual UI and modify options there).
mfg
Russell
- Surface_0_B.FCStd
- (316.04 KiB) Downloaded 92 times
- Surface_0_B-1.png (186.63 KiB) Viewed 2684 times
- Surface_0_B-2.png (191.3 KiB) Viewed 2684 times
Thanks!
Hello Gents,
Low impact comment here to thank you for making the wiki page for 3D Surface. And to mostly thank you for streamlining the acquisition of OCL.
sgrogan specifically: a link for Py 2.7 and a link for Py 3.6! Nice!
I'll switch to FC 0.18 based on 3.6 from now on.
Very, very well done.
Hi everyone.
I am new to this part of the forum. It sounds as if I will find my answer here. I am getting an error in the report view that says "opencamlib is not working" I read through most of the posts and it seems that you have been successful in cimpiling a version for windows. What I am not understanding is if it is an install-able or what I have to do to get it working. I am running the 0.19 version of FC. I checked and I do have the ocl.pyd file located in the lib folder. I dont think this is really causing any of my problems in the path workbench, but I would like to get rid of as much red ink as I can. It will make solving other issues easier.
Charles
Version: 0.19.18811 (Git)
Hash: b809867021deb37be1039dab37b9fe1cafab254e
Python version: 3.7.3
Qt version: 5.12.1
Charles
Qt version: 5.12.1
Hello guys.
I'd like to ask you for help.
I followed the instructions on wiki but newest freecad is compelled with python 3.8.6 but both files are just for python 2.7 and 3.6.
And due to this, I'm getting an error.
do you know how to compile OCL or would be possible to compile it and post in repo?
Or do I still need to have OCL because there is a note that 0.19 doesn't need OCL to install.
Hello, please, I'm quite lost like this guy. I spend many time, tried to compile library and activate and I'm absolutely fail. Please, is here someone who is able to compile library for new Freecad and attach the file for downloading ? I think, that this it would be standard process with release new version of Freecad (with including in bin folder or for download in repo). I guess that i could save many lives haha Thanksinstrukcion14 wrote: ↑Thu Jan 07, 2021 7:21 am Hello guys.
