Hola, buenas tardes,
Usando el Gear workbench, cambia la silueta de los dientes según el nº de dientes sea igual o menor a 60, o si es mayor de 60.
Esto es un problema si hay que combinar engranajes.
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Spanish/Argentina (es_AR)
Gear Workbench
Gear Workbench
- Gear2.jpg (237.88 KiB) Viewed 1470 times
- Gear1.jpg (237.62 KiB) Viewed 1470 times
Re: Gear Workbench
That's a deviation issue. Please try to set the deviation to a smaller value, either via preferences/ partdesign or via the viewproperties
Re: Gear Workbench
Thank you! It was the problem.
