[Solved] Bug #2609 ship worbench doen't work in spanish menu
issue #2609 Posting here to generate conversation
Re: Bug #2609 ship worbench doen't work in spanish menu
It's still a problem. When e.g. trying in German then I get this error message:
File "C:\Projects\FreeCAD-git\ReleaseOCC\Mod\Ship\shipCreateShip\TaskPanel.py", line 53, in accept
Locale.fromString(form.draft.text()))
File "C:\Projects\FreeCAD-git\ReleaseOCC\Mod\Ship\shipCreateShip\Tools.py", line 57, in createShip
ship = Instance.Ship(obj, solids)
File "C:\Projects\FreeCAD-git\ReleaseOCC\Mod\Ship\Instance.py", line 47, in __init__
None))
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xfc' in position 20: ordinal not in range(128)
wmayer wrote:It's still a problem. When e.g. trying in German then I get this error message:
None))
@wmayer then if you don't mind, lets rename issue #2609 to reflect that it's not just an issue in Spanish? Also if you could move this thread to the 'Developers' sub-forum instead?
a.palazzi
Post by a.palazzi »
I've replaced all the str() calls in the Ship module with calls to unicode(), this fixes the problem; there seems to be other issues however, I'll try to also fix them.
I'm not too used to the pull request tool, so I've prepared a patch.
Bye,
Andrea
0001-Replaced-str-with-unicode-in-Ship-module-fixes-2609.txt
(6.09 KiB) Downloaded 66 times
a.palazzi wrote: Sat Jul 29, 2017 9:19 am Hi,
Bye,
Andrea
Thanks Andrea!
yorik wrote:ping
just giving @yorik a heads up ;)
Submitted patch as PR 906
Bye,
Andrea
@a.palazzi FYI patch was merged in git commit 7f4d089715efb2e662
Got any more patches? :)
a.palazzi
Post by a.palazzi »
no more patches - tested yesterday, this one fixes #2609 without other issues.
Bye
Andrea
@a.palazzi i was refferring to this:
a.palazzi wrote: Sat Jul 29, 2017 9:19 am I've replaced all the str() calls in the Ship module with calls to unicode(), this fixes the problem; there seems to be other issues however, I'll try to also fix them.
a.palazzi
Post by a.palazzi »
Kunda1 wrote: Sat Aug 12, 2017 11:56 am @a.palazzi i was refferring to this:
Yes; the fact is that after replacing all the str() calls I tested it and got another, different error. However, when some days later I tested it again, it worked fine and couldn't reproduce the issue.
I finally re-tested it by downloading the binary with my fix from the site, and again I couldn't reproduce the issue, so it seems to work properly as it is.
Bye
Andrea
