Expressions... again...
jmaustpc
Re: Expressions... again...
Post by jmaustpc »
Your first post, welcome to FreeCAD.
You can define values in a spreadsheet in spreadsheet wb and then reference the spreadsheet cell in your expression .
noraef
Post by noraef »
Thanks: yeah, I saw that, but spreadsheets are included in the fcstd file. I was wondering about macros precisely so to share values between different fcstd files...
It's possible that you have a spreadsheet in one document and reference values from there in other documents.
Important note: You use a document's name to reference it from other documents. Now, when saving the document the first time you choose a certain file name and this is usually different to "Unnamed1" (or its translated version) and then the links are lost after reopening it. So, it's recommended to create first the master document, create a spreadsheet, save and close it. After reopening the name is set to the above file name. Afterwards you can still make changes and save the file but you shouldn't rename it.
Then create the further documents where you want to add expressions to. Assuming you named the master document "master" you can access an alias like this: master#Spreadsheet.Length
Unfortunately, the integrated word completion is more confusing than helping because it always gives parser errors or claims that this or that doesn't exist. So, just continue on typing. When you are finished and the content is correct the OK suddenly becomes active.
Of course, it's up to you to load the corresponding documents later when you want to change anything.
So, it's not based on macros but it's already very close to what you may want.
Edit: Add missing word
DeepSOIC
Post by DeepSOIC »
wmayer wrote:It's possible that you have a spreadsheet in one document and reference values from there in other documents.
Unfortunately, the integrated is more confusing than helping because it always gives parser errors or claims that this or that doesn't exist. So, just continue on typing. When you are finished and the content is correct the OK suddenly becomes active.
I copied this to Expressions wiki page. Almost as-is.
noraef
Post by noraef »
@wmayer : ah, it'd be kind of cool, indeed. Unfortunately, changes to the "main" spreadsheet are not applied automagically to all the expressions that call for it.
It will only apply if I enter the dimension definition (eg, the thickness of an extrusion) and validate it. Funny thing is it seems to then check over all the main spreadsheet values (eg, if I extrude an expressed rectangle and I've also modified the sides dimensions in the spreadsheet, manually validating the thickness value will also apply the modifications to the other dimensions). Not too practical once dimensions start being used everywhere...
Also, I noticed the autocompletion starts working if I replace the # by a dot (the latter which is replaced back by a # when I validate the expression definition). Well, that one is not a biggie anyway.
DeepSOIC
Post by DeepSOIC »
noraef wrote: Unfortunately, changes to the "main" spreadsheet are not applied automagically to all the expressions that call for it.
Did you try Macro ForceRecompute?
noraef
Post by noraef »
DeepSOIC wrote:Macro ForceRecompute?
Thanks! It works great with that macro. I did realize the recompute icon was greyed out, but didn't search about macros to solve that.
Added it to the global toolbar, and it'll more than do. Thanks again!
triplus
Post by triplus »
eivindkvedalen wrote: Sun Aug 09, 2015 10:39 pm If you quote them with << and >>, then it works in both cases. You can't use "normal" quote characters like " or ', because that is interpreted as units.
Hi Eivind.
I noticed one issue when helping an user to get a value out of dictionary into a spreadsheet cell:
https://forum.freecadweb.org/viewtopic. ... 76#p214826
If <<>> is used at the end it will get removed from the expression. Consequently after save and open operation resulting in #ERR.
<<Cube>>.Length
Cube.<<Length>>
Note the difference in persistence of <<>>. Any chance this could get fixed? Is there something else that is recommended to be done in such use case? Or are we just pushing the expressions limits to much? ;)
Thanks.
eivindkvedalen
Post by eivindkvedalen »
triplus wrote: Tue Feb 13, 2018 3:39 pm
Hi Eivind.
<<Cube>>.Length
Cube.<<Length>>
Thanks.
You've actually found a way to inject python code; not good, but not sure if this is a security issue or not. Anyway, this should be fixed. Dictionaries and arrays were planned, but not fully implemented. If (when) time allows, I will finish them. The syntax will then be dictionary[key] or array[index], e.g Panel014.Material.Material[Density] in the example from your thread.
Eivind
triplus
Post by triplus »
Thanks for the explanation.
