Expressions... again...
sgrogan
Re: Expressions... again...
Post by sgrogan »
eivindkvedalen wrote:I'll post a pull request when I have added some more documention, and my current pull request to remove warnings is merged ;)
@Eivind
Congratulation on this and THANK YOU!
This was one of the most requested features. I admire your perseverance and dedication to this.
"fight the good fight"
ickby
Post by ickby »
Hello Eivind,
I'm looking into binding the expressions of properties in the property editor. One question I can't find anything about: is it possible to bind expressions to a properties subvalue? For example if I have a quantify spin box for each component of a vector x y and z, can I bind this somehow? This would be handy for placements in the property editor.
eivindkvedalen
Post by eivindkvedalen »
ickby wrote:Hello Eivind,
Hi, this is possible using the ExpressionBinding::bind(const App::ObjectIdentifier & _path) method. You need to construct an ObjectIdentifier object, which you can do either with ObjectIdentifier::parse(...), or you can construct it like I have done in PropertyConstraintList::createPath(int ConstrNbr). The first one actually invokes the parser, so the second method is preferred as that is just object construction, even though it is a bit cumbersome to write. In your case, it would be something like
App::ObjectIdentifier(docObj)
<< App::ObjectIdentifier::Component::SimpleComponent(App::ObjectIdentifier::String("Placement"))
<< App::ObjectIdentifier::Component::SimpleComponent(App::ObjectIdentifier::String("Base"))
<< App::ObjectIdentifier::Component::SimpleComponent(App::ObjectIdentifier::String("x"))
to access the x value of the placement vector.
Eivind
ickby
Post by ickby »
thanks, this looks really easy! I will see how well this integrates into the property editor, but my first experiments seems to work very well
pablogil
Post by pablogil »
Eivind
Could you please write or record a simple tutorial on now to do this? I'm totally newbie about this kind of "complex expressions" but it feels so powerful...
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
eivindkvedalen
What ickby and I were discussing is low-level access to properties from C++. He has started on the user interface to make expressions available in the property editor for regular users. However, for the time being, it is possible to set expressions on arbitrary properties (or sub-properties) from Python by using the setExpression function. For example, to set the placement vector, you can issue something like
App.ActiveDocument.Sketch.setExpression('Placement.Base.x', '20mm +2mm')
If you want to extend FreeCAD in C++, I suggest that you look at the PartDesign and Sketcher modules first, and also the Expression classes in App. The gui part is mainly the QuantitySpinBox and ExpressionBinding classes. Those are the two that have their GUI updated to support expressions.
For user documentation, please also see http://www.freecadweb.org/wiki/index.ph ... xpressions
Eivind
brusk
Post by brusk »
Thank you so much for Expressions, Eivind!
This is how I always wanted to use FreeCAD :D !
Two notes:
1) When editing an expression I can close the autocomplete drop down and the expression text field with the return key. But it stops working then, when only the constraints editor (the one where it's possible to specify the name of the constraint) is showing, even though the Ok-button is blue, indicating that it's the default button. It's a minor thing and maybe not even related to your work, it could just be nice to be able to press enter, enter, enter instead of having to reach for the mouse.
2) By accident I created a copy of the spreadsheet I am pulling values into expressions from. After I deleted the copy suddenly all my sketches involving expressions was showing errors. Inspecting them I found that my spreadsheet, "Sheet", had been renamed to "Sheet001" in all the expressions. And since I had deleted the copy they were no longer valid. Is that how it's supposed to work?
microelly2
Post by microelly2 »
eivindkvedalen wrote: However, for the time being, it is possible to set expressions on arbitrary properties (or sub-properties) from Python by using the setExpression function. For example, to set the placement vector, you can issue something like
Very nice to use Interface. I used it in my animations and it works fine.
It's still not documented but it makes a lot of things much easier.
Is there already a tutorial for this function I did not see?
Will you extend it for other datatypes too?
brusk
Post by brusk »
brusk wrote:When editing an expression I can close the autocomplete drop down and the expression text field with the return key. But it stops working then, when only the constraints editor (the one where it's possible to specify the name of the constraint) is showing, even though the Ok-button is blue, indicating that it's the default button. It's a minor thing and maybe not even related to your work, it could just be nice to be able to press enter, enter, enter instead of having to reach for the mouse.
Ah, one just needs to press tab once to be able to use the enter key in the end :) .
eivindkvedalen
brusk wrote:2) By accident I created a copy of the spreadsheet I am pulling values into expressions from. After I deleted the copy suddenly all my sketches involving expressions was showing errors. Inspecting them I found that my spreadsheet, "Sheet", had been renamed to "Sheet001" in all the expressions. And since I had deleted the copy they were no longer valid. Is that how it's supposed to work?
No, but I'm not able to recreate the problem here... :(
EDIT: Sometimes I hit some weird behaviour when I delete objects. I know this is related to the expressions somehow, but have so far not been able to recreate it consistently here. Any help on recreating the problem above would be appreciated :)
Eivind
Last edited by eivindkvedalen on Sun Nov 29, 2015 12:26 pm, edited 1 time in total.
