[tracker] bugs in the toponaming branch
This thread is to collect bugs and flaws you find in the toponaming branch, see its announcement:
https://forum.freecadweb.org/viewtopic.php?f=10&t=73017
Please report every issue in a separate post to this thread.
To keep the overview, this post will get a list of reported issues and their status (as we e.g. did for the TD development: https://forum.freecadweb.org/viewtopic. ... 15#p366615).
Re: [tracker] bugs in the toponaming branch
It was suggested to mention this Part TNP discussion: https://forum.freecadweb.org/viewtopic. ... 91#p636291
Thanks.drmacro wrote: ↑Sat Oct 29, 2022 11:39 am It was suggested to mention this Part TNP discussion: https://forum.freecadweb.org/viewtopic. ... 91#p636291
Since this thread is to collect particular bugs, can you please describe the bug you found in a new post in a way that it can be reproduced to be fixed?
For info: I mad now the announcement of the first toponaming build:
Please use this build for testing and bug reports (this assures that everybody uses the same code base).
Select Part workbench.
Create a sketch, create a rectangle.
Close the sketch.
Extrude the sketch.
Select the top face.
Close the sketch.
Extrude the sketch
Select both extruded
Boolean union
Open the first sketch, add a hole, close the sketch
Second extrudecis now on the bottom face of first extrude.
See video in previously linked post.
Close the sketch.
Extrude the sketch.
Close the sketch.
Extrude the sketch
Boolean union
I don't use conda or appimage.uwestoehr wrote: ↑Sun Oct 30, 2022 12:19 amThanks.drmacro wrote: ↑Sat Oct 29, 2022 11:39 am It was suggested to mention this Part TNP discussion: https://forum.freecadweb.org/viewtopic. ... 91#p636291
The version I used is built daily from the topo branch on github.
I have reproduced this bug using freecad snap (--channel=latest/edge/toponaming).
My result is even more wired because also the x,y position changes after adding a hole to the first sketch:
Really, now there's a surprise...
Yes I have also seen that this problem doesn't happen with LinkDaily.
To be more precise in both cases (TopoNaming-v1 and LinkDaily) the face name switches from Extrude-face6 to Extrude-face7 when the circle (hole) is added to first sketch.
The difference is that in LinkDaily the support of the second sketch is updated accordingly while in TopoNaming-v1 it is not and it keeps pointing to Extrude-face6.
Nope, I did not say that, Nsikak1 said that. I said it in a different thread.
