[resolved] Build freecad broken !
paddle
Post by paddle »
I just sync my fork master on freecad master.
Pulled changes on my local.
Built my master branch without making any changes.
And FreeCAD is broken:
If someone can check if it's also broken on their side.
nic
Re: Build freecad broken !
Post by nic »
It's ok on my side
OS: Ubuntu 20.04.5 LTS (Regolith:GNOME-Flashback:GNOME/regolith)
Version: 0.21.30487 (Git)
Build type: Unknown
Hash: f4b4aabc3234d793b6a852c7c415aa17917688fc
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: French/France (fr_FR)
  * B777-300
  * Assembly4 0.12.4
  * Behave-Dark-Colors 0.1.1
  * DynamicData 2.46.0
  * MOOC 2022.4.21
  * SelectorToolbar
  * fasteners 0.4.6
  * sheetmetal 0.2.57
mfro
Post by mfro »
same here. Works fine:
OS: Debian GNU/Linux bookworm/sid (GNOME/gnome)
Python 3.10.7, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.7.0.dev
  * Help 1.0.3
  * Assembly4 0.12.3
  * Help.backup1661594724.9387012
  * Behave-Dark-Colors.backup1661598364.718598
  * Assembly4.backup1661591923.0362408
  * Curves 0.5.6
Cheers,
Markus
openBrain
Post by openBrain »
Did you tried a clean build from scratch?
paddle
Post by paddle »
Yes I rebuilt the whole project twice.
Not sure what is wrong. It could be cmake configuration. Sounds like a blast to debug.
I went back to paddle_testing_branch which is older and it's working well again.
openBrain
Post by openBrain »
Did you delete/rename your configuration files to check they don't mess up the app?
paddle
Post by paddle »
openBrain wrote: Thu Sep 29, 2022 2:49 pm Did you delete/rename your configuration files to check they don't mess up the app?
I'm not sure what this means. What configuration files? I haven't changed anything I think.
paddle
Post by paddle »
Anyone on windows confirm it's working? I realized both who tried are on linux
openBrain
Post by openBrain »
paddle wrote: Thu Sep 29, 2022 7:35 pm I'm not sure what this means. What configuration files? I haven't changed anything I think.
I mean deleting/renaming "%APPDATA%\FreeCAD" folder. ;)
paddle
Post by paddle »
openBrain wrote: Fri Sep 30, 2022 8:31 am I mean deleting/renaming "%APPDATA%\FreeCAD" folder. ;)
I didn't touched that.
I only sync my fork's master then pulled locally. git log shows me that the last commit locally are the correct ones. So it really feels like master is not compiling on windows.
Though I guess maybe my cmake configuration (the one I'm using for a year) is not compatible with master anymore (as I have disabled some wb to compile faster)?
