#define FC_LOGLEVEL_DEFAULT -1
#define FC_LOGLEVEL_ERR 0
#define FC_LOGLEVEL_WARN 1
#define FC_LOGLEVEL_MSG 2
#define FC_LOGLEVEL_LOG 3
#define FC_LOGLEVEL_TRACE 4
#define _FC_LOG_LEVEL_INIT(_name,_tag,...) \
static Base::LogLevel _name(_tag,## __VA_ARGS__);
#ifndef FC_LOG_INSTANCE
# define FC_LOG_INSTANCE _s_fclvl
#endif
#define FC_LOG_LEVEL_INIT(_tag,...) \
_FC_LOG_LEVEL_INIT(FC_LOG_INSTANCE, _tag, ## __VA_ARGS__)
#define __FC_PRINT(_instance,_l,_func,_msg,_file,_line) do{\
if(_instance.isEnabled(_l)) {\
std::stringstream _str;\
_instance.prefix(_str,_file,_line) << _msg;\
if(_instance.add_eol) \
_str<<std::endl;\
Base::Console()._func(_str.str().c_str());\
if(_instance.refresh) Base::Console().Refresh();\
}while(0)
#define _FC_PRINT(_instance,_l,_func,_msg) __FC_PRINT(_instance,_l,_func,_msg,__FILE__,__LINE__)
#define FC_MSG(_msg) _FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_MSG,NotifyMessage,_msg)
#define FC_WARN(_msg) _FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_WARN,NotifyWarning,_msg)
#define FC_ERR(_msg) _FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_ERR,NotifyError,_msg)
#define FC_LOG(_msg) _FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_LOG,NotifyLog,_msg)
#define FC_TRACE(_msg) _FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_TRACE,NotifyLog,_msg)
#define _FC_MSG(_file,_line,_msg) __FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_MSG,NotifyMessage,_msg,_file,_line)
#define _FC_WARN(_file,_line,_msg) __FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_WARN,NotifyWarning,_msg,_file,_line)
#define _FC_ERR(_file,_line,_msg) __FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_ERR,NotifyError,_msg,_file,_line)
#define _FC_LOG(_file,_line,_msg) __FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_LOG,NotifyLog,_msg,_file,_line)
#define _FC_TRACE(_file,_line,_msg) __FC_PRINT(FC_LOG_INSTANCE,FC_LOGLEVEL_TRACE,NotifyLog,_msg,_file,_line)
#define FC_XYZ(_pt) '('<<(_pt).X()<<", " << (_pt).Y()<<", " << (_pt).Z()<<')'
#define FC_xy(_pt) '('<<(_pt).x<<", " << (_pt).y<<')'
#define FC_xyz(_pt) '('<<(_pt).x<<", " << (_pt).y<<", " << (_pt).z<<')'
#ifndef FC_LOG_NO_TIMING
# define FC_TIME_CLOCK high_resolution_clock
# define FC_TIME_POINT std::chrono::FC_TIME_CLOCK::time_point
# define FC_DURATION std::chrono::duration<double>
# define _FC_TIME_INIT(_t) _t=std::chrono::FC_TIME_CLOCK::now()
# define FC_TIME_INIT(_t) FC_TIME_POINT _FC_TIME_INIT(_t)
# define FC_TIME_INIT2(_t1,_t2) FC_TIME_INIT(_t1),_t2=_t1
# define FC_TIME_INIT3(_t1,_t2,_t3) FC_TIME_INIT(_t1),_t2=_t1,_t3=_t1
# define _FC_DURATION_PRINT(_l,_d,_msg) \
FC_##_l(_msg<< " time: " << _d.count()<<'s');
# define FC_DURATION_MSG(_d,_msg) _FC_DURATION_PRINT(MSG,_d,_msg)
# define FC_DURATION_LOG(_d,_msg) _FC_DURATION_PRINT(LOG,_d,_msg)
# define FC_DURATION_TRACE(_d,_msg) _FC_DURATION_PRINT(TRACE,_d,_msg)
# define _FC_TIME_PRINT(_l,_t,_msg) \
_FC_DURATION_PRINT(_l,Base::GetDuration(_t),_msg);
# define FC_TIME_MSG(_t,_msg) _FC_TIME_PRINT(MSG,_t,_msg)
# define FC_TIME_LOG(_t,_msg) _FC_TIME_PRINT(LOG,_t,_msg)
# define FC_TIME_TRACE(_t,_msg) _FC_TIME_PRINT(TRACE,_t,_msg)
# define FC_DURATION_DECLARE(_d) FC_DURATION _d
# define FC_DURATION_DECLARE2(_d,_d1) FC_DURATION_DECLARE(_d),_d1
# define FC_DURATION_DECLARE3(_d,_d1) FC_DURATION_DECLARE2(_d,_d1),_d2
# define FC_DURATION_INIT(_d) _d=FC_DURATION(0)
# define FC_DURATION_INIT2(_d,_d1) _d=_d1=FC_DURATION(0)
# define FC_DURATION_INIT3(_d,_d1,_d2) _d=_d1=_d2=FC_DURATION(0)
# define FC_DURATION_DECL_INIT(_d) FC_DURATION _d(0)
# define FC_DURATION_DECL_INIT2(_d,_d1) FC_DURATION_DECL_INIT(_d),_d1(0)
# define FC_DURATION_DECL_INIT3(_d,_d1) FC_DURATION_DECL_INIT2(_d,_d1),_d3(0)
# define FC_DURATION_PLUS(_d,_t) _d += Base::GetDuration(_t)
#else //FC_LOG_NO_TIMING
# define _FC_TIME_INIT(...) do{}while(0)
# define FC_TIME_INIT(...) do{}while(0)
# define FC_TIME_INIT2(...) do{}while(0)
# define FC_TIME_INIT3(...) do{}while(0)
# define _FC_DURATION_PRINT(...) do{}while(0)
# define _FC_TIME(_t) do{}while(0)
# define FC_DURATION_PRINT(...) do{}while(0)
# define FC_DURATION_INIT(...) do{}while(0)
# define FC_DURATION_INIT1(...) do{}while(0)
# define FC_DURATION_INIT2(...) do{}while(0)
# define FC_DURATION_DECLARE(...)
# define FC_DURATION_DECLARE1(...)
# define FC_DURATION_DECLARE2(...)
# define FC_DURATION_DECL_INIT(...) do{}while(0)
# define FC_DURATION_DECL_INIT2(...) do{}while(0)
# define FC_DURATION_DECL_INIT3(...) do{}while(0)
# define FC_DURATION_PLUS(...) do{}while(0)
#endif //FC_LOG_NO_TIMING
BestPractise / GoodPractise / Acceptable / Dodgy / Unacceptable?
