Addon Manager Developer Mode
Re: Addon Manager Developer Mode
Thx chennes!
As a side note I have this warning:
It work correctly in:
But the error is present in:
I think that the culprit could be these multiple invocation of QtWebEngineProcess, taken from a:
when FC "terminal window" is not closing, I invoke FC using a script that issue the 6875 command to launch my "conda-install" version.
EDIT:
This the output of the same command after starting FC without trying to use the AddOn Manager.
But it close correctly the "terminal windows" if I exit from FC
As a side note FC 0.20.1 is an AppImage.
Hope it help.
And it blocks the exit from the session, that I start from a terminal using a script, forcing me to close the "terminal window" but FreeCAD window is closing correctly. If you need further infos feel free to ask.Worker process check_for_python_package_updates_worker is taking a long time to stop...
OS: Artix Linux (openbox)
Locale: Italian/Italy (it_IT)
* Curves 0.5.8
Version: 0.21.30398 (Git)
Hash: b3dfdc568a92810449bf47bc73b6784d65dfa206
* test_wb
* fcgear 1.0.0
* Assembly4 0.12.4
* toSketch 1.0.1
* Curves 0.5.8
* Help 1.0.3
ps ax
6875 ? S 0:00 urxvt -T FreeCAD-launcher -e freecad
6876 pts/3 Ssl+ 1:34 freecad
6893 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
6894 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
6909 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
6946 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
7065 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/bin/python3
7165 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
7350 pts/3 Sl+ 0:02 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
8370 ? S 0:00 urxvt -T FreeCAD-launcher -e freecad
8371 pts/3 Ssl+ 0:02 freecad
8388 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
8389 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
8404 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
8406 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
8455 pts/1 R+ 0:00 ps ax
Hope it help.
Thanks, I have some time now I'll see if I can poke at that check_for_python_package_updates_worker problem now.
I added a timeout to the pip process, can you let me know if this has an affect on your bug?
git commit 9e1ed4a68
As soon conda-install is updated I will surely let you know.
If AddonManager could be made an AddOn itself or cloned in the user Mod dir, it will be more easy.
Regards.
I've added a new metadata tag, <pythonmin>, that allows Addon developers to specify a minimum required version of Python. I've also added a scanning feature to the Addon Manager Developer Mode that uses the Vermin package to scan your addon and determine what it things is your required minimum version of Python based on the features you use. This tag will be ignored by older versions of FreeCAD, so it is safe to include in your package.xml metadata file.
Also seeing this withonekk wrote: ↑Wed Sep 21, 2022 3:23 pm As a side note I have this warning:
OS: Artix Linux (openbox) Word size of FreeCAD: 64-bit Version: 0.20.1.29410 (Git) AppImage Build type: Release Branch: (HEAD detached at 0.20.1) Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563 Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2 Locale: Italian/Italy (it_IT) Installed mods: * Curves 0.5.8
I think that the culprit could be these multiple invocation of QtWebEngineProcess, taken from a:Code: Select all
OS: Artix Linux (openbox) Word size of FreeCAD: 64-bit Version: 0.21.30398 (Git) Build type: Release Branch: master Hash: b3dfdc568a92810449bf47bc73b6784d65dfa206 Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3 Locale: Italian/Italy (it_IT) Installed mods: * test_wb * fcgear 1.0.0 * Assembly4 0.12.4 * toSketch 1.0.1 * Curves 0.5.8 * Help 1.0.3
when FC "terminal window" is not closing, I invoke FC using a script that issue the 6875 command to launch my "conda-install" version.Code: Select all
ps ax
EDIT:Code: Select all
6875 ? S 0:00 urxvt -T FreeCAD-launcher -e freecad 6876 pts/3 Ssl+ 1:34 freecad 6893 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 6894 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 6909 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 6946 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 7065 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/bin/python3 7165 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 7350 pts/3 Sl+ 0:02 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
But it close correctly the "terminal windows" if I exit from FCCode: Select all
8370 ? S 0:00 urxvt -T FreeCAD-launcher -e freecad 8371 pts/3 Ssl+ 0:02 freecad 8388 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 8389 pts/3 S+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 8404 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 8406 pts/3 Sl+ 0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces 8455 pts/1 R+ 0:00 ps ax
Hope it help.
OS: Ubuntu 22.04.1 LTS (KDE/plasma)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
* sheetmetal 0.2.57
* Manipulator 1.4.9
* lattice2 1.0.0
* fcgear 1.0.0
* Curves 0.5.8
* Assembly4 0.11.8
* fasteners
* A2plus 0.4.59d
* ThreadProfile 1.84.0
* Assembly3 0.11.3
* VendorParts
Running from CLI:
1.12302 <asm3.main> init_gui.py(14): no solver backend found
pip took longer than 30 seconds to return results, giving up on itTraceback (most recent call last):
File "/tmp/.mount_FreeCAPVl7Ys/usr/Mod/AddonManager/manage_python_dependencies.py", line 54, in run
if check_for_python_package_updates():
File "/tmp/.mount_FreeCAPVl7Ys/usr/Mod/AddonManager/manage_python_dependencies.py", line 64, in check_for_python_package_updates
outdated_packages_stdout = call_pip(["list", "-o", "--path", vendor_path])
File "/tmp/.mount_FreeCAPVl7Ys/usr/Mod/AddonManager/manage_python_dependencies.py", line 112, in call_pip
raise Exception(proc.stderr.decode())
UnboundLocalError: local variable 'proc' referenced before assignment
Can you let me know if git commit 9b4183581 resolves the issue for you?
chennes wrote: ↑Mon Oct 03, 2022 9:31 pm Can you let me know if git commit 9b4183581 resolves the issue for you?
* sheetmetal 0.2.58
* Manipulator 1.4.9
* lattice2 1.0.0
* fcgear 1.0.0
* Curves 0.5.10
* Assembly4 0.11.8
* fasteners
* A2plus 0.4.59d
* Assembly3 0.11.3
* VendorParts
File "/tmp/.mount_FreeCA508knG/usr/Mod/AddonManager/manage_python_dependencies.py", line 54, in run
File "/tmp/.mount_FreeCA508knG/usr/Mod/AddonManager/manage_python_dependencies.py", line 64, in check_for_python_package_updates
File "/tmp/.mount_FreeCA508knG/usr/Mod/AddonManager/manage_python_dependencies.py", line 112, in call_pip
That’s the same version, you will need to update before it works. At the very least the line number of the error will change.
