Addon Manager Developer Mode
chennes
Post by chennes »
I've just pushed a large changeset to the Addon Manager, adding a beta version of a new "Developer Mode", designed to help developers package up their addons for distribution. As a first task, it assists with creating a correct package.xml metadata file.
To activate the mode, check the box in Preferences:
Screen Shot 2022-09-09 at 12.58.42 PM.png (191.19 KiB) Viewed 3152 times
That will enable a new button in the Addon Manager:
Screen Shot 2022-09-09 at 12.59.06 PM.png (36.08 KiB) Viewed 3152 times
Which will activate a whole sequence of dialogs, centered around this one:
Screen Shot 2022-09-09 at 12.59.50 PM.png (177.92 KiB) Viewed 3152 times
This is still very much a work in progress, so I welcome your feedback, bug reports, and feature suggestions.
Chris Hennes
Pioneer Library System
Re: Addon Manager Developer Mode
Amazing work @chennes !
HakanSeven12
Post by HakanSeven12 »
Nice
'Addon Manager Developer Mode' is now available in the latest Snap 'edge' for those wanting to test @chennes's feature.
obelisk79
Post by obelisk79 »
This seems really good, well done chennes!
chennes
Post by chennes »
I should also note that I tweaked the actual metadata standard while I was working on this, most notably adding the "optional" and "type" attributes to dependencies. These changes are backwards-compatible (previous versions of FreeCAD will just ignore them) and they are of course optional.
I'm planning on making another change as part of my longer-term plan to ensure that users stuck on older versions of FreeCAD don't accidentally get updated to a version of an Addon that is no longer compatible with that version, but I'd like to get some feedback on what that looks like before I implement it. I am thinking of something along the lines of:
<release version_lt="0.20">abcd1234</freecad> <!-- Older versions of FC always get this specific hash, no updates -->
<release version_eq="0.20">FC0_19_Branch</freecad> <!-- v0.20 has its own maintenance branch -->
<release version_gt="0.20">main</freecad> <!-- Anything after 0.20 should use the branch called "main" -->
The syntax here is exactly the same as the dependency attributes, except that the "version" referred to uses FreeCAD's version, and the tag contents are a git reference of some kind (hash, tag, or branch). I don't really like the "release" nomenclature, but I haven't thought of anything better, so please feel free to make a suggestion.
Chris Hennes
chennes wrote: Thu Sep 15, 2022 7:18 pm Developer Tools is brand new, I added it at the beginning of this week.
Now with:
OS: Artix Linux (openbox)
Version: 0.21.30398 (Git)
Hash: b3dfdc568a92810449bf47bc73b6784d65dfa206
Locale: Italian/Italy (it_IT)
  * Curves.backup1662281788.2751102 0.4.1
  * fcgear.backup1662281841.5151978 1.0.0
  * Assembly4.backup1663652740.0704694
  * test_wb
  * fcgear 1.0.0
  * Assembly4 0.12.4
  * Curves 0.5.8
  * Help.backup1662281850.737508 1.0.3
  * Help 1.0.3
It seems that developer tools are usable (and I've used them to validate a package) and save it:
but I've noted that the format is "not compliant" with the examples:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<package format="1">
  <name>OpenSCAD alternate importer</name>
  <description>An alternate OpenSCAD importer - with some experimental features</description>
  <version>1.0.0</version>
  <maintainer email="keith@sloan-home.co.uk">Keith Sloan</maintainer>
  <license file="LICENSE">GPL-2</license>
  <url branch="master" type="repository">https://github.com/KeithSloan/OpenSCAD_Alt_Import</url>
  <url type="readme">https://github.com/KeithSloan/OpenSCAD_Alt_Import/blob/master/README.md</url>
  <url type="documentation">https://github.com/KeithSloan/OpenSCAD_Alt_Import/wiki</url>
  <icon>freecad/OpenSCAD_Alt_Import/Resources/icons/OpenSCAD_Alternate.png</icon>
  <date>2022-08-18</date>
  <content>
    <workbench>
      <freecadmin>0.20.0</freecadmin>
      <tag>openscad</tag>
      <tag>scripting</tag>
      <tag>programming</tag>
      <classname>OpenSCAD_Alt_Import</classname>
      <subdirectory>./</subdirectory>
    </workbench>
  </content>
</package>
<package format="1" xmlns="https://wiki.freecad.org/Package_Metadata">
  <name>Legacy Workbench</name> <!-- What the Addon Manager displays to users -->
  <description>Text that the Addon Manager shows for the Addon. Any length, but remember that Addon Manager's compact view only shows the first sentence or so.</description>
  <version>1.0.1</version> <!-- Semantic versioning (1.2.3-beta) or CalVer-based, (2022.01.07), don't omit or non-git installations won't see your updates -->
  <date>2022-01-07</date> <!-- Date of the last update to the version number -->
  <maintainer email="your_address@null.com">Your Name</maintainer>
  <license file="LICENSE">LGPL-2.1</license> <!-- Make sure you actually have this file in your Addon repo if the license requires it -->
  <url type="repository" branch="main">https://github.com/chennes/FreeCAD-Package</url> <!-- Don't forget to update the branch name here -->
  <url type="readme">https://github.com/chennes/FreeCAD-Package/blob/main/README.md</url> <!-- Link to the HTML-rendered README page -->
  <icon>Resources/icons/PackageIcon.svg</icon> <!-- If you include your icon here, you don't have to submit it to the main FreeCAD repo -->
  <content>
    <workbench>
      <classname>MyLegacyWorkbench</classname> <!-- Must match class name in InitGui.py -->
    </workbench>
  </content>
</package>
notably the
and in the workbench stanza some elements have a different order.
I have uploaded the "processed package.xml" to the site, to see if it is working correctly.
It seems that however the <name> used is taken from .gitmodules and not from the package.xml as it shown the "Alternate OpenSCAD...." instead of "OpenSCAD alternate importer" present in the package.xml.
EDIT:
As a side note I have this warning:
Worker process check_for_python_package_updates_worker is taking a long time to stop...
And it blocks the exit from the session, that I start from a terminal using a script, forcing me to close the "terminal window" but FreeCAD window is closing correctly. If you need futher informations feel free to ask.
chennes
Post by chennes »
A few points:
  1. The order of the elements does not matter, and the XML writer is allowed to write them however it wants. So the formatting and order is basically out of my control, and doesn't affect anything.
  2. The XML is missing the required namespace element, so I do have to address that.
  3. The displayed name sounds like it's wrong, so I'll look into that.
Chris Hennes
chennes wrote: Tue Sep 20, 2022 4:16 pm ...
Thanks for your work, and for you patience.
XML order is more a cosmetic thing, as usual a little note in the documentation will be useful IMHO, as probably other user will complain of "changed order".
chennes
Post by chennes »
  1. The XML is missing the required namespace element, so I do have to address that.
Fixed by git commit 49e37dd61.
Chris Hennes
