Help with git for testing Addon Manager
Re: Help with git for testing Addon Manager
chennes wrote: Tue Aug 09, 2022 9:07 pm Using which command?
maybe
git rev-list --count master...origin/master
the remote has to be fetched up to date for this. Check other options of this command if the output of --count is not satisfactory. It's probably a good idea to programmatically get the correct tracked branch and local branch that need to be compared rather than just assuming it's the default.
chennes wrote: Tue Aug 09, 2022 9:16 pm Oh sorry -- although it does do a fetch every time, it's really looking at the output of git status to determine the up-to-date status. Nevertheless, if I specifically reset to a specific revision, git status returns nothing.
Ah that's probably a better option, in my testing after resetting to a prior commit I do get the info by running
git status --ahead-behind
example output:
On branch master
Your branch is behind 'origin/master' by 2 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
nothing to commit, working tree clean
edit: running git status on its own also shows the same output but this might be something dependent on the local config so it's better to explicitly ask for it IMO.
chennes
Post by chennes »
It's not working for me yet: when I do a hard reset to a specific revision, git status doesn't give me any results...
chennes@chrismaclaptop 3DfindIT % git reset --hard b9ab38a
HEAD is now at b9ab38a Make sure to execute javascript from the main thread.
chennes@chrismaclaptop 3DfindIT % git status --ahead-behind
On branch master
And rev-list gives:
chennes@chrismaclaptop 3DfindIT % git rev-list --count master...origin/master
fatal: ambiguous argument 'master...origin/master': unknown revision or path not in the working tree.
Chris Hennes
Pioneer Library System
do you have the remote properly configured and the correct tracking branch set? That is very weird.
chennes
Post by chennes »
The Addon Manager doesn't do any configuration beyond just doing a plain "git clone", so that's what I've got.
Chris Hennes
adrian@DESKTOP-PAKQOHR:~$ git clone https://github.com/cadenasgmbh/3dfindit-freecad-integration
Cloning into '3dfindit-freecad-integration'...
remote: Enumerating objects: 149, done.
remote: Counting objects: 100% (149/149), done.
remote: Compressing objects: 100% (101/101), done.
remote: Total 149 (delta 75), reused 89 (delta 33), pack-reused 0
Receiving objects: 100% (149/149), 338.65 KiB | 281.00 KiB/s, done.
Resolving deltas: 100% (75/75), done.
adrian@DESKTOP-PAKQOHR:~$ cd 3dfindit-freecad-integration/
adrian@DESKTOP-PAKQOHR:~/3dfindit-freecad-integration$ git reset --hard b9ab38a
adrian@DESKTOP-PAKQOHR:~/3dfindit-freecad-integration$ git status --ahead-behind
On branch master
Your branch is behind 'origin/master' by 6 commits, and can be fast-forwarded.
could it be due to git version? this is running 2.25.1 in ubuntu 20.04
this suggests the remote is not called origin in your clone though, what's the output of
git status -sb --porcelain
this could be easier to parse, here it gives:
## master...origin/master [behind 6]
chennes
Post by chennes »
Maybe, I am running 2.32.1 on Mac OS. I just tested on Windows with 2.29.2 and the normal "get status" gives me your results. Adding "--porcelain" still gives nothing, which is unfortunate, and I'm a little concerned about the inconsistency.
Chris Hennes
chennes
Post by chennes »
adrianinsaval wrote: Wed Aug 10, 2022 3:30 pm
It works beautifully on my Windows machine, but on the Mac I just get "##master" -- I wonder if there's something wrong with git version 2.32.1 (Apple Git-133).
Chris Hennes
looks like it doens't have a tracking branch, did you try in a newly cloned repo or is this always in the same repo? What's the output of
git branch -a
chennes
Post by chennes »
* master
So maybe this is just something like a really old checkout, or I've broken it, or something
Chris Hennes
