sounds good, to avoid any confusion, @gneiss in the source it would go into src/Ext/freecad and I believe you have to add the file to the relevant cmake file so that it gets installed with the rest.wmayer wrote: What about Ext/freecad? If you put there a file myModule.py you can import withCode: Select all
from freecad import myModule
[Bug?] AppImage version of FreeCad can't use AppImage of OpenScad (and possible other externals)
- adrianinsaval
Re: [Bug?] AppImage version of FreeCad can't use AppImage of OpenScad (and possible other externals)
Sorry, I missed this thread for some while (working on different things)...
Thanks to all who give me some hint were to place the module..
I currently use another aproach (especialy for OpenScad). I start this vai a bash-script. That work, but my solution described above is clearly better, so I will continue on this theme in about 2 month (Next Year), sorry for the delay...
