[fixed] [regression] [TD] not compilable
uwestoehr
Re: [regression] [TD] not compilable
Post by uwestoehr »
wmayer wrote: Sun Jun 26, 2022 10:38 am The current master compiles fine on Linux and with clang on MSYS/MinGW. It's only the MSVC compiler that sucks.
I updated now from MSVC 2019 to 2022 but I get the exact same linker error.
There is no need that QGVPage directly inherits from ParameterGrp::ObserverType. It can also be moved to a private class that will be declared and implemented in the source file. So, the QGIView no longer sees the extra ParameterGrp::ObserverType.
So, can you try this please?
td_msvc_fix_link_failure.txt
(6.39 KiB) Downloaded 12 times
wandererfan
Post by wandererfan »
@wmayer Thank you. This seems to work fine on linux.
@uwestoehr a branch with the patch applied is available here: https://github.com/WandererFan/FreeCAD/tree/wmPatch
uwestoehr
Post by uwestoehr »
wmayer wrote: Sun Jun 26, 2022 6:03 pm So, can you try this please?
Many thanks!
This works. Since @wandererfan already reported it works for him too, I committed it now (that I have a compilable master :) ).
LarryWoestman
Post by LarryWoestman »
I just pulled and successfully built "master" on Windows 11 with MSVC, so it worked for me, also :-)
Re: [fixed] [regression] [TD] not compilable
@wandererfan
While talking about the issues of git commit 9894964eb69e90 there is one further minor thing:
the class QGSPage defines the members m_renderer, drawBkg and balloonCursor that are initialized in the constructor but then used nowhere else. clang raises e.g. the warning warning: private field 'm_renderer' is not used [-Wunused-private-field].
Will the class QGSPage be extended by using the members in some methods or can they be removed?
wandererfan
wmayer wrote: Mon Jun 27, 2022 9:58 am Will the class QGSPage be extended by using the members in some methods or can they be removed?
QGSPage (QGraphcisScene) is new and took over some scene related tasks that were in QGVPage (QGraphicsView). It is entirely possible some QGVPage code came along for the ride. Eventually, QGSPage will handle things like box selection of edges.
Thanks for catching this. I will check it out.
