Correct me if I'm wrong, (I'm not very used to the python API build system), but it's seems like some methods don't show up in the Python API.
For instance, the trace() method is does not exist (i.e. calling FreeCAD.Matrix.trace yield a "not found" error), but the MatrixPy.xml define it (line 102-109) and the MatrixPyImp.cpp actually implement it (line 481-490).
Do I miss something ?
OS: Debian GNU/Linux 11 (bullseye) (XFCE/xfce)
Version: 0.19.
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.1
[Solved] Missing method in Matrix form Python API
Re: Missing method in Matrix form Python API
Please add you full About info to your OP please
What source you are using to affirm the above. If you refer to GitHub usually you are in the developing version (now it is not far from the 0.20 just released) and not the 0.19 you have in the infos above.
Probably you have to state even from what source you will derive information above and affirm that they are wrong.
I'm actually reading the code of origin/master at 588331515d9c1a08a174123b80a6d94b49cd9ed2, and using FreeCAD freshly build using this.
OK so the info above are not correct, you are using 0.20 ?
Well, first, I have to figure out why the hell I'm at this commit, it about 4 month old... git fetch don't update my local :/ I will work on it, and I will be back !
EDIT: Call me dumb, I didn't update my fork since then...
I update, rebuild, and come back
Ok nevermind, just **correctly** built 0.21, and trace() show up
Sorry for the inconvenience !
git fetch will not update sources, it downloads the changed data.
git pull usually do fetch and merge changes.
But I'm not a git expert (I usually made big messes when collaborating with git).
Git was acting fine, in fact, it's just that it was fetching the fork I use to make pull request, and I didn't update my fork since February to stay up to date with the FreeCAD origin (I've basically forgot his existence, and assumed I was pulling from FreeCAD repo...)
