Release notes for FreeCAD 0.21
uwestoehr
Post by uwestoehr »
This is the forum thread for new 0.21 features.
Here is the Wiki page for the release notes: https://wiki.freecadweb.org/Release_notes_0.21
bensay
Re: Release notes for FreeCAD 0.21
Post by bensay »
Removal of deprecated functions in TechDraw
https://github.com/FreeCAD/FreeCAD/pull ... 7113035295
[TechDraw] Remove deprecated replaceCosmeticVertex
[TechDraw] Remove deprecated replaceCosmeticEdge
[TechDraw] Remove deprecated replaceCenterLine
[TechDraw] Remove deprecated replaceGeomFormat
uwestoehr
Post by uwestoehr »
bensay wrote: Tue Aug 02, 2022 8:39 pm Removal of deprecated functions in TechDraw
Thanks.
Please add them directly to
https://wiki.freecadweb.org/Release_not ... provements
(In case you have no Wiki permissions yet, please ask for them in the Wiki subforum. You develop a lot and you will most probably also have to update the TechDraw docs.)
vlk
Post by vlk »
New material card for Ti-6Al-4V Grade 5 alloy:
https://github.com/FreeCAD/FreeCAD/pull/8636
uwestoehr
Post by uwestoehr »
vlk wrote: Sun Feb 26, 2023 11:44 am New material card for Ti-6Al-4V Grade 5 alloy:
Thanks, it is now mentioned.
Utkarshkumar
Post by Utkarshkumar »
extend command Part_PointsFromMesh to support any geometric type
#8730
uwestoehr
Post by uwestoehr »
Utkarshkumar wrote: Sat Mar 04, 2023 4:14 pm extend command Part_PointsFromMesh to support any geometric type
#8730
Thanks. Could you make a proposal for the text (1 or 2 sentences)? I am asking because looking at the PR I cannot figure out what the novelty is.
Roy_043
Post by Roy_043 »
I have changed the subject of this topic from:
Release notes for FreeCAD 1.0
to:
The OP has been changed accordingly.
See:
viewtopic.php?t=77989
jonasb
Post by jonasb »
Roy_043 wrote: Sat Apr 29, 2023 6:18 pm I have changed the subject of this topic from:
to:
The page still links to FreeCAD 1.0 Development Cycle.
While the content of section "Minimum supported library versions" does apply to 0.21, the rest of the page most certainly doesn't.
Roy_043
Post by Roy_043 »
I have removed the link.
