Problem with unicode in menu after switching language
Roy_043
Post by Roy_043 »
I want to change "Bezier tools" to "Bézier tools" (with accent aigu) in a Draft menu. This works fine. But after changing the GUI language the e with accent aigu gets mangled.
Test:
  • Switch to the Draft WB.
  • Run this code:
    wb = Gui.activeWorkbench()
    wb.appendMenu(["Drafting 2", "Bézier tools"], "Draft_BezCurve")
  • Switch to another WB and then back to the Draft WB.
  • Test the "Drafting 2" menu: the e with accent aigu looks fine.
  • Change the GUI language.
  • Again test the "Drafting 2" menu: the e with accent aigu is mangled. See image.
  • Note that it does not matter what the initial GUI language is.
Is this a bug? Or do I need to use a particular encoding?
