Making constraint 'clear' when sketchHandler active
paddle
Post by paddle »
When a constrain is on top of a geometry, it makes the geometry difficult to select.
select cstr.png (29.63 KiB) Viewed 2310 times
When you're in general edit mode it's good because you want to be able to select either constrain or geometry. But when you are using a constrain tool, then it can be annoying because you can't select easily the geometry as the constrain get preselected (as it's drawn on top). (while my picture is a simplistic example, when a sketch gets a lot of elements it gets fairly annoying.)
In ViewProviderSketcher::mousemove, I could easily add a 'ignore constrain' bool, as follow :
if (Mode == STATUS_SKETCH_UseHandler) {
            //don't preselect constraints if a sketcher tool is being used. It seems there isn't any usecase to select constrain while a sketcher tool is active.
            //If there is then we need to add a parameter to not ignore.
            preselectChanged = detectAndShowPreselection(Point.get(), cursorPos, true /*ignore constraints*/);
        else {
            preselectChanged = detectAndShowPreselection(Point.get(), cursorPos);
Which makes the constrain impossible to preselect/highligth. However the underneath line still doesn't get selected. As the constrain still renders on top and apparantly prevent the detection of the line.
I went dipper in
editCoinManager->detectPreselection
But it doesn't give more hints. Just that constrain is preselected in the first place only if no curves are found.
So it seems this doesn't trigger :
        // checking for a hit in the curves
        if (tail == editModeScenegraphNodes.CurveSet[l]) {
            const SoDetail *curve_detail = Point->getDetail(editModeScenegraphNodes.CurveSet[l]);
            if (curve_detail && curve_detail->getTypeId() == SoLineDetail::getClassTypeId()) {
                // get the index
                int curveIndex = static_cast<const SoLineDetail *>(curve_detail)->getLineIndex();
                result.GeoIndex = coinMapping.getCurveGeoId(curveIndex, l);
                return result;
So it might need to check in deeper. But before spending so much time on it, does anyone know something on that?
edit: sorry my title is bad. It should be 'Making constrain clear to selection when sketchHandler is active'
Re: Making constraint 'clear' when sketchHandler active
is temporarily changing the rendering order an option?
paddle
Post by paddle »
adrianinsaval wrote: Wed Jan 19, 2022 3:19 pm is temporarily changing the rendering order an option?
Yes I think so, do you know how to do that?
unfortunately I don't
Syres
Post by Syres »
paddle wrote: Wed Jan 19, 2022 3:40 pm
Is the following link a helpful hint or causes more questions https://github.com/FreeCAD/FreeCAD/comm ... bb81043a81
openBrain
Post by openBrain »
paddle wrote: Wed Jan 19, 2022 3:40 pm Yes I think so, do you know how to do that?
IMO the best solution is to add a 'SoPickStyle' node in the scenegraph just above 'ConstraintGroup'.
Then when you activate an handler, you set its style value to 'SoPickStyle::UNPICKABLE'.
When deactivating the handler, you set it back to 'SoPickStyle::SHAPE'.
You can test it with following code (run it when a sketch is in edit mode) :
from pivy import coin
er = Gui.ActiveDocument.ActiveView.getSceneGraph().getByName('EditingRoot').getByName('Sketch_EditRoot')
cg = er.getByName('ConstraintGroup')
ps = coin.SoPickStyle()
ps.style.setValue(ps.UNPICKABLE)
er.insertChild(ps, er.findChild(cg))
At this time constraints are no more selectable. To get this back, just :
ps.style.setValue(ps.SHAPE)
You'll eventually have to add another SoPickStyle node with SHAPE value just after the 'ConstraintGroup' node so following nodes aren't disturbed by the changes.
openBrain
Post by openBrain »
Something like this ? https://github.com/0penBrain/FreeCAD/co ... 1899b7bc7b
paddle
Post by paddle »
Whoa this was quick !
Looking great from your gif.
It would be great if it's pushed to upstream :)
openBrain
Post by openBrain »
paddle wrote: Wed Jan 19, 2022 5:45 pm Whoa this was quick !
I added a link to the commit on my fork in my above post so you can eventually test and see if it matches your expectations.
If you think it does, I can push it as a PR to the master. ;)
EDIT : or I can push a draft PR if it's simpler for you to compile and test. ;)
paddle
Post by paddle »
openBrain wrote: Wed Jan 19, 2022 5:55 pm I added a link to the commit on my fork in my above post so you can eventually test and see if it matches your expectations.
Hmm I have no idea how to get your branch on my local git.
I'll search for it and try it! My new git challenge!
