Connecting C++ widget to Python
Re: Connecting C++ widget to Python
@wmayer wrote a new Python wrapper for the SheetView that's accessible from the ViewProvider, so though I never figured out why the problem was occurring, we're bypassing it now.
Not directly related to this thing, but only with the error issued by FreeCAD.
The "deleted object error" is happening also when you try to iterate through a document to delete all objects.
Sometimes this code will fail:
I have to put a try: except: around doc.removeObject to avoid such error, maybe it is related to the way object is constructed when deleting an object it will delete his childs but doc.Objects are retaining childs and when it try to delete them they are already gone.
For sure it is my fault in coding.
Sorry for the OT.
def clear_doc(doc_name):
"""Clear the document deleting all the objects.
Parameters:
name type description
doc_name string document name
doc = FreeCAD.getDocument(doc_name)
doc.recompute()
objects = doc.Objects
for obj in objects:
if obj.TypeId in ("App::"):
pass
else:
doc.removeObject(obj.Name)
Sorry for the OT.
This is not related to the reference counting issue of PySide but the order in which you remove objects from the document. If e.g. have a body and remove it then everything inside will be removed, too.The "deleted object error" is happening also when you try to iterate through a document to delete all objects.
doc = App.ActiveDocument
doc.addObject("PartDesign::Body")
doc.Objects
# [<body object>, <App::Origin object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>]
doc.removeObject(doc.Objects[0].Name)
doc.Objects
Whenever you try to access any attribute if the underlying C++ object is destroyed it raises a ReferenceError, i. e. that obj.TypeId will fail, too. So, you must use the try/except block around the if/else block.I have to put a try: except: around doc.removeObject to avoid such error
for obj in objects:
try:
pass
else:
except ReferenceError as e:
pass
